brake booster nipple removal.
Got my motor in today, and when looking over the motor, looks like I will need to install the nipple into the rear of the intake for my brake booster.
I happen to work for a dealership and we actually had an old intake manifold for my motor laying around. I could not figure out how to remove the nipple from the manifold. I can't pull it out and it won't unscrew. Any Ideas?
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
![]() Join Date: Dec 2012
Re: brake booster nipple removal.
Push in the on whole nipple and red collar. Hold the red collar in and the nipple should pull out.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Ok now the dumb question.... Push in on the red collar toward the manifold right?
Sorry manifold is at work and I'm home now so it's not in front me to fiddle with. Seems like I tried all sorts of combinations trying to remove it, just wanting to make sure I'm pushing in the right direction. Again sorry for the dumb question and thanks for the help!
In the current picture you need to push in on the red collet toward the manifold and the nipple should slide out nice and easy.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() Last edited by First c10; 01-07-2016 at 10:29 PM. |
Like this.
Awesome thank you now I get it.
Will try as soon as I get to work tomorrow.
![]() Join Date: Sep 2005
Is there any numbers on the plug you have? Alot of us have been trying to find thT plug i just have mine caped off
meowMEOWmeowMEOW
Truckdude are you looking for the actual vacuum nipple piece? (what he shows in the pic).
or are you looking for a factory part to block that port off?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
TruckDude, the 5.3l for my swap, came from a Tahoe with hydraboost, and had the plug in the plenum. I removed the plug for a vacuum nipple. If you need a plug, you can have mine (I saved it). PM me if you want it
Lee |
#10 | |
I had my dealer try to find the part numer but they had no luck
I have never found a GM part number for the plug and i have been looking for years. In this thread is some info on what will also work. Post #6 http://ls1tech.com/forums/conversion...l#post18528131
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Thanks again guys. I got to work this morning and it came right off. Thank you again.
#13 | |
Guys I removed the nipple and installed a tee 1 vacuum line to the booster and another one to the AC canister
Removing that plug was the first TRICK the folks on here taught me about L S engines!!
The fuel lines was the second one, but I needed a tool
#15 |
