Old 01-07-2016, 08:50 PM   #1
Longley428
What shocks for a 4/6 drop
I'm in the process of lowering my 69 c10 and using the 4/6 spring kit from hotchkis, what shocks do I need for this? Also in the rear I will be adding a 2" lowering block as well
Longley428 is offline   Reply With Quote
Old 01-08-2016, 12:10 AM   #2
Longley428
Re: What shocks for a 4/6 drop
Also will I “need" an adjustable track bar as well on the rear?
Old 01-08-2016, 10:14 PM   #3
Longley428
Bump? Anyone?
Old 01-08-2016, 11:26 PM   #4
Mike C
Mike C's Avatar
I have a 4/7 on my leaf spring flip and I ran front shocks all around. KYB G2 from Rock Auto. I re-drilled the upper mount to get the shock a little more vertical. Can't help on track bar as I don't have one.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-09-2016, 12:38 AM   #5
Longley428
Thanks for the reply! Ok I will check those out, I finished up with installing the front springs tonight, and noticed with the truck jacked up on the frame and suspension is at full droop the new springs are loose/wiggle around when the control arms fall down. Is this normal with lowering springs? Again I just have oem shocks on the truck. I hope this isn't a dumb question, just want to make sure everything is correct. Would shorter drop shocks help with controlling th droop not be as far?
Old 01-09-2016, 10:04 AM   #6
Mike C
Mike C's Avatar
Yes, it's normal. That's how the truck gets lower is the spring is much shorter. I would search for "lowering shocks" on the top of the page. Type in the bar and just the button for 67-72chevytrucks.com as I would hate to steer you wrong on the rear shocks for a coil sprung truck.
But with 2 1/2" spindles and 2" lowering springs, stock shocks on my truck work fine.
44 Willys MB
52 M38A1
64 Corvette Coupe
