Old 01-09-2016, 08:46 AM   #1
mgb
mgb's Avatar
4"drop from a 3"spring
How much do I cut off of a 3" drop spring to get 4" drop?
mgb is offline   Reply With Quote
Old 01-09-2016, 08:55 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 4"drop from a 3"spring
That's going to be a hard question to get answers on .It's like asking what color is white ? Different manufactures ,Varying spring tension and no one wants to give you an unintentional misleading measurement at best it's going to be a guesstimate .
Old 01-09-2016, 09:04 AM   #3
Boog
laying low
Boog's Avatar
If removing 1 coil on a stock spring nets about 2" then a 1/2 coil should net about 1" approximately.
However, the general line of thinking is that going with any more than a 3" spring drop only on front leads to alignment issues.
The better approach is 2 1/2" or 3" dropped spindles + 1, 2" springs.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-09-2016, 09:25 AM   #4
mgb
mgb's Avatar
When you say "drop only on front", if I'm dropping the back 5", will that help me on alignment
Old 01-09-2016, 09:53 AM   #5
EARNHARDT#3
EARNHARDT#3's Avatar
He means drop spring. You're better off doing a spindle drop or a spindle/spring combo to get your desired amount of drop.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 01-09-2016, 12:02 PM   #6
C/10 King
C/10 King's Avatar
........and get ready for most likely a lousy ride....
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
