![]() Join Date: Oct 2008
Tricks for Sagging Headliner?
So the original headliner on my Cheyenne Super is sagging pretty bad... and the trim around it is kinda warped.
To fix the headliner -- I assume I use liquid nails, some good 3M adhesive or some VHB double-sided 3M tape? To fix the trim -- Not sure? It looks like I could add a couple of screws to the area where it is warped the most. But the truck is really stock and unmolested so I dont love the idea of putting a handful of holes in it that weren't supposed to be there Any suggestions are appreciated! ![]() |
Re: Tricks for Sagging Headliner?
Get some 3M 3/4 inch double sided tape and do the mouldings. Use trim adhesive to do the headliner back to the board then use it again to glue the board to the roof.The double sided tape can be bought a little thinner but the 3/4 should be perfect for the trim and you not have to trim any of it off. You also may want to try 3M Ultra pro trim adhesive i use it to replace trim parts.
Member
A heat gun will help restore the original shape of the moldings. Go easy with the heat....
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
Thanks Guys!
custom1970 I see you are in Stuart FL. I have family down there! |
Member
Well the truck is rather original looking.... Tell them to keep a look out... I've been here a while , small town , we probably have mutual friends.
