![]() Join Date: Mar 2009
Stock height 2wd 69-72 blazer or jimmy pics?
Hey gang, just wondering if there are any stock height 2wd blazers left out there?
I recently purchased a 71 blazer that was a 4x4 and the previous owner started to convert it to 2wd. I was planning on just using the Tub to replace the tub on my 70 4x4 but its not as nice as I thought. So now I'm not sure what I want to do with it but thought about completing the conversion to 2wd but making it look stock instead of lowered. I'm not sure I've ever seen a stock height 2wd blazer or jimmy. If anyone has some stock 2wd blazer or jimmy pics please post them up.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
Re: Stock height 2wd 69-72 blazer or jimmy pics?
I guess there are fewer than I thought but no one has any pics?
They look like 4 wheel drives.....
![]() Not mine, but I took these pics at a show last year.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
this was mine before it was lowered
Posted via Mobile Device |
![]() Join Date: Feb 2013
Here's my 70 2wd with and without the top. It's still got the optional factory "Heavy Duty Springs" in front and back. Not sure how much that effects the ride height.
Zac 1970 Factory 2wd Blazer |
Yep, they look just like 4x4's.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
so (this is a pretty embarrassing question to ask), but does anybody know the difference in a stock height 2wd VS a 4wd?? i have a 4wd that i'm trying to return to stock height. i bought new front replacement leaf springs (23.5" eye to eye; 1 1/8" arc), installed them, and now for the rear end to sit "level" with the front, i had to put in 3" lift blocks?? that doesn't make any sense to me.
this is how it looks now (again, with stock replacement springs up front, and 3" blocks in the back), and the front is sitting 1/2" higher than the rear (i assume it'll be pretty level, but the rear doesn't have any shocks installed right now). **the top of the wheel well is measuring 39.5" from the ground on the front, and 39" on the rear.
Alan 1965 Chevy Suburban. LT1, 4L60e, bagged |
Here's my 70 Jimmy I had from 94-07. Terrible pic of a pic, 400sb, 4spd, 3:73 posi. Fast and a blast to drive.
Sideways of course, dang it!!
Med Blue with top is stock height 4x4, Dark Blue with no top is my stock height 2wd. Both had the exact same size tires. Although I didn't get any measurements while I had them both, they are damn near identical.
Edit--- I didn't scroll up to see that I posted this pic already. ![]()
thanks man...i honestly can't really even guess what's going on. i confirmed with the company that these are stock springs. i asked if they were "made to order", thinking perhaps someone made a pair that weren't the correct specs, and he said that they sell a ton of them, so they're made in bulk, and he doesn't know what's going on.
what's also weird is the axle seems to be pushed towards the rear of the truck?? i think i'm going to start a new thread just to see if that gets a bit more visibility, because i'm honestly at a loss.
I'm not a 4x4 guy, but I remember the front leaf springs having a reversed arch in them. I have another 4x4 frame at the house with no drivetrain or front clip on it, if it will help, I'll snap some pics tonight when I get home and take some measurements for you.
Could it be as simple as they are mounted upside down??
