Old 01-13-2016, 05:05 PM   #1
HackJob65
Early 12 bolt posi
Just came across this figured I'd post for someone looking http://www.ebay.com/itm/Chevy-GMC-Tr...dWktAY&vxp=mtr
HackJob65 is offline   Reply With Quote
Old 01-13-2016, 10:49 PM   #2
northern
northern's Avatar
Re: Early 12 bolt posi
How does one tell if its from a truck or car? Pinion shaft dia. needed.
Brad
64 C-10, 406 sbc
th350, ford 9" floater
northern is offline   Reply With Quote
Old 01-14-2016, 02:05 AM   #3
Captainfab
60-66 Nut
That IMO is definitely a '63-'64 truck 12 bolt posi unit. That has the very heavy springs with the aluminum plates. Some refer to it as a Dana posi unit. That would be a decent deal for someone with a '63 or '64 that still has the 17 spline axles.
Old 01-14-2016, 10:49 AM   #4
OldChevy61
OldChevy61's Avatar
Is there a way to tell if its 17 spline by just pulling the cover off or do you have to pull the axle. I know mine came back as 63,64, but I know they changed axles in mid to late 64.
OldChevy61 is offline   Reply With Quote
Old 01-14-2016, 05:52 PM   #5
HackJob65
You had better pull an axle my truck is a 65 and has the 17sp axles as well as the longer track bar with the large bracket welded to housing tube
