01-14-2016, 01:10 PM | #1 |
Wilwood C10 Drop Spindles
I don't know if this has been posted yet on here. I posted it on the 73-87 threads but they cover all C10 trucks figure I would post it here also.
01-14-2016, 01:12 PM | #2 |
Re: Wilwood C10 Drop Spindles
And.
01-19-2016, 09:14 PM | #3 |
Thanks for the info wish they where out now
02-02-2016, 12:49 PM | #4 |
Thanks for sharing this, I'm highly interested in these!
02-02-2016, 01:38 PM | #5 |
I would have rather gone with these than the CPPs but oh well.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
02-02-2016, 05:18 PM | #6 |
I love these things. OE/dropped iron spindles are heavy mofo's.
02-02-2016, 10:18 PM | #7 |
Anyone know if they change track width?
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
02-02-2016, 11:01 PM | #8 |
Saw these at PRI, they looked awesome.
Just watch out they will only be available with the later ball joint configuration... 73-up. They didn't have all the details ironed out at that point but it was looking like 1 spindle would set you back what a set of cpp/ridetech spindles cost. But of course ther are also using vette hubs. |
02-03-2016, 02:25 AM | #9 |
And weight savings.....
02-04-2016, 09:43 AM | #10 | |
Any how, I spoke with Wilwood Tech last night, here's a copy of what I posted over at pro-touring... I spoke with Wilwood Tech last night and they assured me that the hub assemblies will but much heavier than the Corvette hubs, as I questioned that also. They also said any variation from factory track width should be kept minimal, maybe .188 at most on the offset. And should work with aftermarket, replacement control arms. So us guys that have the Hotchkis for example should be able to upgrade with no issues. I was contemplating on going with CPP spindles, but had heard some remarks about the axle pins shifting under heavy load, as they are pressed in. So far, I'm highly interested in these ne Wilwood pieces. |
02-03-2016, 08:48 AM | #11 |
Yea I want these. Once someone gets their hands on these share it with the forum!
02-04-2016, 09:46 AM | #12 |
02-04-2016, 10:00 AM | #13 |
02-03-2016, 11:43 AM | #14 |
I'm really digging these but not sure I want to buy a 3rd set of spindles for a truck that appears will never be finished because I keep changing my mind or companies keep coming out with cooler stuff
02-03-2016, 09:12 PM | #15 |
Rob from No Limit shares some thoughts here in second post. http://www.pro-touring.com/threads/1...0-pro-spindles!!
02-04-2016, 11:27 AM | #16 |
Talked with our Wilwood rep about these, sounds like they did a lot of homework. The hubs are a bit stronger than generic vette. - Still not sure if you can use OE brakes or if you have to use Wilwood parts. We thought about this approach for our next run of WR spindles, and could not justify the cost-vs-performance angle. For us, it showed that the cost of a new IFS would go up appx $800, and no longer include brakes. We were spec'ing new F-body brakes as a starting point, but even OE brakes would add appx $1200, and aftermarket like Wilwood adds $2K. This all driving the cost of a new IFS up way past $4K, and closer to $5K. For an update, if you are staying with the OE crossmember and geometry, these new Wilwood units can be added at any time, and may seem more reasonable cost. And, if you were planning a brake upgrade anyway, that cost is about equal.
Whats nice here is to see a company step up the technology and help move more of these old trucks into the 21rst century.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
06-25-2016, 07:08 PM | #17 |
Has anyone heard when these will be available.
Thanks. |
06-26-2016, 07:56 PM | #18 |
motor exploder
I've been checking Wilwood's website regularly and they still don't even have the part numbers in the system or a listing for them on the ProSpindles tab of the site. Maybe a phone call to them is in order.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-29-2016, 08:54 PM | #19 |
. Subscribed for future updates... . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
08-15-2016, 07:26 PM | #20 |
I want
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
09-05-2016, 12:19 PM | #21 |
Any updates ?
09-06-2016, 11:57 AM | #22 |
Spoke with a Wilwood rep at Goodguys Pleasanton.
He couldn't say for sure but was thinking maybe around SEMA. He indicated that the steering arms were the last piece to the puzzle. |
09-29-2016, 03:43 PM | #23 |
Diggin The SquareLife
just seen on wilwoods ig that they have released these
09-29-2016, 04:13 PM | #24 |
67-72 parts collector,…
Looks like you HAVE to run 73-87 balljoints for these.
I assume outer tie rods also.
09-30-2016, 06:30 PM | #25 |
I scored
