01-17-2016, 01:14 PM | #1 |
custom trailing arms for 14 bolt rear-end installs
Ok guys, need some input. Unless these already exist, and I just don't know how to properly "search", does such a trailing arm exist? I know you can get the brackets to weld on, but I would think there surely would be interest in just "bolt on" arms. Bolt on in front as usual and rear would mount where the leaf pack was. Easy enough for for weekend warriors as a option without the need for welding and fabbing. Reason for asking, thoughts in my head of a 65 c-20 with 14 bolt cab &chassis rear would be neat. The narrower width would give better wheel options.
01-17-2016, 04:43 PM | #2 |
Re: custom trailing arms for 14 bolt rear-end installs
I must be the only one curious.
01-17-2016, 08:39 PM | #3 |
I think the issue is arms would have to be built based on the donor rear, and set designed for each donor. Would be hard to do. Many of the donor rears are under slung.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-22-2016, 06:37 PM | #4 |
Thanks PGSingns
