engine switch
I have a 69 c-10 2wd with 245 six cyln and three on a tree, all factory. I have a 305 V-8 that is now hookewd up to an auto trans. I want to installl the 305 with a 4spd Saginaw manual trans. Do I need to get different flywheel and housing, or will the six cyln fit?
Fabricate till you "puke"
the clutch pcs from your 250 will bolt right on the 305. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
is the 6cyl 3 on the tree the same as a 350? if so I might be intrested in your 3 speed and parts if you do the swap.
Be sure you put a pilot bearing in the crank.
engine switch
Thanks to all that responded. It appears I was right and my friend wrong... haha!
Locutus, I am not going to do this for a couple months, and I am not sure if it will fit. DC |
