09-20-2003, 09:55 PM | #1 |
AND HOLDING ON TO THE C10
vette engine in my truck need help on identifying a piece on the intake
help i don't know what the piece bolted on the intake is? and what is it's purpose my choke won't work right puzzled
66 swb/ss chevy c10 SOLD 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 91 sdime 383/th350 Last edited by truckman32; 09-20-2003 at 09:58 PM. |
09-20-2003, 10:17 PM | #2 |
On my intake my EGR is in the same location...but your EGR is farther back...so..I dunno...maybe a heat-crossover block-off plate...
09-20-2003, 10:28 PM | #3 |
its the feed pipe for a hot air choke. if you look at it, there should be a small hole in it. that hole leads into a tube which loops around, and comes back out, and then goes to your choke.
09-21-2003, 12:47 AM | #4 |
Gentleman Jim Driver
Yep, that is exactly the same setup as what I just got done (well, I still have to put one heater hose back on and fill the cooling system) pulling off my Gentleman Jim.
You can see the fitting on the top-back centerline of the carb that is disconnected, there should be a metal tube between it and that hole in the plate that screws to the intake you pointed at. It should still work though, you are just drawing unfiltered air into the choke rather than filtered.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
09-22-2003, 05:42 AM | #5 |
thanks for all the info i done some more research and found out what it's purpose was 1faastc10 you were exactly right.thanks
66 swb/ss chevy c10 SOLD 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 91 sdime 383/th350 |
