PLEASE HELP, FACTORY Antenna hole in wrong spot, Pics inside
Ok guys, I have spent 150 bucks on antennas and keep coming up with the wrong ones. I have ordered the factory replacement solid mast and telescoping one. both are designed to mount higher than my factory hole and are not flat on the bottom like the one that came off of my truck. Here are part numbers and pictures. SOMEONE PLEASE tell me where to get the correct antenna for my truck. I cant find a single picture of a truck like ours with this antenna hole.
heres the telescopic http://www.summitracing.com/parts/GMK-4143170671S heres the fixed, which I would rather have http://www.classicindustries.com/pro...rts/c2599.html Has anyone ever used one of these in a hole like mine??? MY HOLE LOL ![]() MY OLE ANTENNA BASE ![]() THE NEW ANTENNA BASE, BOTH ARE IDENTICAL AND BOTH CAME WITH THE TEMPLATE TO PUT IT UP HIGHER ![]() TEMPLATE HOLE OVER MY HOLE FOR SIZE COMPARISON, NOT WHERE IT ACTUALLY GOES. ![]() WHERE THE NEW ANTENNAS ACTUALLY GO. ![]()
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
Roadtrip!
![]() Join Date: Feb 2003
Re: PLEASE HELP, FACTORY Antenna hole in wrong spot, Pics inside
You are probably getting the right antennas, the hole in your cowl doesn't look correct to me.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#3 | |
https://41.media.tumblr.com/tumblr_m...8vi9o1_500.jpg
Member #1049
Unfortunately the hole in your cowl for the antenna is not in the factory location, the two antennas you purchased are designed to use the factory location, One thing you might try is to find the chrome base and lever off of a late 70's to early 80's Chevy van, they use the same antenna as your truck and uses flat base
#5 | |
https://farm8.staticflickr.com/7134/...8893555f_b.jpg
![]() Join Date: Oct 2015
Almost looks like a 66 antenna?
Exactly what I am looking at right now, Looks very very close. Did the 66 antennas have a slot in the base so they could be angled a little bit?
pretty sure its a 66. This is a members truck on here. looks identical on the base and looks like it does tilt like mine did.
http://i1112.photobucket.com/albums/...007_081053.jpg
Yeah looks close to me!
Well I am going to take one more chance cause I want a solid mast This one is only 14 bucks anyway. I gotta ship all these other back now.
http://www.crutchfield.com/p_12044GM...M-Antenna.html
was not a factory installed but a dealer or other aftermarket install
Carpe manana
![]() ![]() Join Date: Dec 2010
Does the glovebox SPID list a radio as factory installed?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
It's long gone.
#15 |
I am having the same issue with my antenna. Did you ever come up with a solution?
Posted via Mobile Device |
#16 |
I ended up using a universal antenna from crutchfield. I used a solid non telescopic. Very happy with it. Give me a minute I will see if I can find it again
#17 |
I ended up testing all the bases and went with the one with the smallest slope to make it concentric with the lines of the truck. Worked perfect and if anyone steals the mast or bends it I can replace it without pulling out the internal wires. This blew my mind because I tried 4 antennas from 4 well known 67-72 companies and none of them were correct. They were all 50 or so each after shipping.
heres the link. let me know if it doesn't work!!! http://www.crutchfield.com/p_12044GM...M-Antenna.html
#18 |
Thanks. Yea i bought one from classic parts and it needed like a 1" hole.
#19 |
How big was the hole in your cowl and did that antenna seem to be decent quality?
#20 |
i never measured it but I would say it was around a 1" hole. I think its good quality. been there a while and looks like it belongs there
#21 |
Could you possibly post a pic of it on your truck?
#22 |
Try these. Damn love bugs everywhere
#23 |
Looks good. Thanks
