70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Question for Folks Running Full LED's
I want to put LED's in my 1972 C10 truck for all the outside bulbs, except headlights which we be upgraded but not LED. In the original fuse panel it shows 1 flasher for signal lights and one for the hazard lights. Do I have to replace both flashers with LED flashers so the hazards will work as they should, if I need them, or will just replacing the signal light flasher be sufficient.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Question for Folks Running Full LED's
I just had to replace one with a No Load flasher on my 72 . I got it from NAPA .
Old member
I replaced both of mine to make them blink right and not be slow are fast depending on what manufacture bulb you use.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Some LED lamps have a shunt load built in so that it's enough draw to run the blinkers; the safer bet is to get one that works with zero load.
Read the package to see what kind of sound it makes though - maybe a full digital one beeps instead of clicks, I'm not sure what happens if there's no physical relay.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
That is the one I replaced both mine with. Works great with all LED.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
That looks like the same one I used .
Thanks for the replys
I just finished this same endeavor and it was a pain due to my lack of knowledge with electrical work. If I were you I would do both electronic flashers and make sure you have the reverse polarity adapters in case you have to use them (I did). The biggest thing is making sure you ground your front parking lamps well! Ground your flashers well too. Make sure you grind down to clean metal when grounding all your wires.
1971 c20 LWB Fleet 2wd 'working' Add-on AC & Working heat/defrost manual transmission w/ Power steering & power brakes Family owned since 1971 ![]() ____________________________________ “Life is rough so you gotta be tough” - Johnny Cash |
