01-25-2016, 07:48 PM | #1 |
Brake Shoe too Tight
I'm installing new brake shoes on my 69 C10 front drums the one facing the front , smaller pad is way too tight, the hold down spring is overly tight and the shoe will not even move by force, the bigger shoe facing the rear is fine, I don't know what to do, pictures soon as soon as I can do it
01-26-2016, 02:15 AM | #2 |
Re: Brake Shoe too Tight
yea, show us a pic so we can see how ya put it together
01-26-2016, 04:08 AM | #3 |
01-26-2016, 08:42 AM | #4 |
Are the hold down pins the same length as the ones you removed
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-26-2016, 12:11 PM | #5 |
Put the rest of the parts in....adjuster, lower spring, upper spring
01-26-2016, 12:45 PM | #6 |
Like this and I think the green spring goes on the bottom with the self adjuster. anyway your missin a bunch of goodies
01-26-2016, 12:12 PM | #7 |
are the shoes the same width? the front one looks wider
1970 short step c10 leaf spring 454 |
01-26-2016, 03:22 PM | #8 |
Did you do one at a time? Like can you compare to the other side? I never attempt a drum brake without a working reference one... until you've done enough of them, just too many springs to go in the wrong location!
Love these mechanical solutions to complicated problems. Discs are such a simpler idea.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-26-2016, 04:43 PM | #9 |
I am doing one at the time, before the picture, I had all the springs on and felt like everything was going to blow off after I start to brake, I checked the brake shoes compared to the Old ones and they are the same, and the Pins are the same size, this is honestly frustrating me, I will Restart it all
01-26-2016, 05:43 PM | #10 |
Did you replace or rebuild the wheel cyl.? If a piston is stuck it will not let it go back in. You must o-haul or replace a wheel cyl. on every brake job.
01-28-2016, 02:02 AM | #11 |
The trailing shoe does not look correctly installed into anchor pin or wheel cylinder..
72 C20 Longbed 05 1500 Z71 |
01-28-2016, 04:20 PM | #12 |
Here are 2 pictures that may help. The first is the left front during my teardown process. The second is the right front during the rebuild process. Mine is a 3/4 ton but is basically the same as a 1/2 ton.
As stated above you have parts missing and the rear shoe is not properly seated/positioned. |
