01-27-2016, 01:49 PM | #1 |
Clearance around bags
I am installing some Slam Specialties SS-7 bags in my 1949 Chevy 3600.
Thunderbird IRS in the back, Scott Danforth Cross Member in the front. I am setting the back up now and I am a little tight on space with the 7" bag. I plan to open up the notch a little since I have room available. Is there a rule of thumb.....or a guideline on how clearance you should have around the bag to prevent chaffing or a rub? Thanks in advance? |
01-27-2016, 02:23 PM | #2 |
Re: Clearance around bags
I try and make sure I have a 1/2 inch. On you welds, slow down on the travel and maybe turn up the heat. The ones on the sides look like they have little penetration.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-27-2016, 02:42 PM | #3 |
Thanks for the input.
01-28-2016, 03:01 AM | #4 |
I was always told a finger gap between the bag and anything it could touch.Anything the bag rubs on could rub a hole in it over time since its rubber.
01-28-2016, 10:55 AM | #5 | |
Thanks!! |
01-28-2016, 10:57 AM | #6 |
Why not go w/a smaller OD bag? The 7" bag is better suited for the front weight bias on a truck.
01-28-2016, 10:59 AM | #7 | |
I just really did not want to go through the hassle of selling these bags, buying new, etc. |
01-28-2016, 11:03 AM | #8 |
Seems easier vs the option of cutting & opening up the notch more since it appears a little thin as-is (might just be the angle on the pics).
01-28-2016, 11:18 AM | #9 |
I am not too worried about the integrity of the notch, but you have me thinking.
Is there a ride quality difference between the two bags? |
01-28-2016, 11:53 AM | #10 | |
Some guys may not notice. I definitely could.
