01-27-2016, 06:49 PM | #1 |
power steering and brakes on 62 chevy truck
i want to put power steering and power brakes on my 62 chevy truck. Is this possible with just finding parts at a local salvage. Ive shopped a few different websites but its kind of pricey. Hoping maybe i can just put some parts togethor and make it work.
01-27-2016, 06:59 PM | #2 |
One foot in front of the other
Re: power steering and brakes on 62 chevy truck
What motor? You staying with drums?
01-27-2016, 07:01 PM | #3 |
What trans you running?
01-28-2016, 12:33 AM | #4 |
60-66 Nut
Yes it can be done with good used original parts, That is how I have always done it. You will need a steering box adapter plate and a booster bracket. I do make those.
01-28-2016, 12:15 PM | #5 |
i have a 4 speed muncie
01-28-2016, 11:54 AM | #6 |
Im putting a 350 motor in it. I want to put disc brakes all the way around if possible. But for now i think i will just stick with changing the front to disc and leaving the rear if that can be done. thanks for asking. Im all new to this forum never used one in my life
01-28-2016, 12:09 PM | #7 |
I have disc's on the front of my 62, they are off a 1978 c10 (crossmember swap)
I also have power steering from the same vehicle with an adapter plate. I had a custom power steering hose made to adapt the LS style PS pump to the old PS box. Take your time reading these forums they are a wealth of info and lots of good guys to help you out. |
01-28-2016, 12:44 AM | #8 | |
The 60-62 frames and suspension are different then the 63-66. So unless you find a 60-62 that has been converted to power brakes and power steering at the junk yard you will not find anything that will just bolt in. But.. if you want disc brakes .. you can get a 72-87 C10 cross member ( get everything control-arms gear box ,pump hoses etc) and swap that in. There is a great write up in the FAQ section. Or go the route I did on my 60 and use a 1972 gear box and CPP 60-62 power steering adapter or get one from member Captainfab. again 60-62 specific adapter I used 2.5" drop spindles to convert to disc. see link http://67-72chevytrucks.com/vboard/s...ight=1960+disc There are other things to keep in mind, as mentioned what motor/tranny do you have? If it is a manual transmission you need to address the hydraulic clutch. I put together mine but again Captainfab can help you with that. You will need power-steering pulleys v8 are easy to find L6 are a bit harder to come across. Do it ! Well worth the effort. Capt you beat me with your info !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-28-2016 at 12:52 AM. |
01-28-2016, 02:37 AM | #9 | |
With the CPP steering plates you have to drill holes in those. Captain fab is out of plates. Is there actually no other company that makes a quality plate? Last edited by smoothone; 01-28-2016 at 02:51 AM. |
01-28-2016, 12:06 PM | #10 | |
I had no issues with the plates I had to drill one hole. I have had zero issues with the CPP plate and its been on my truck for over 5 years. CPP makes two styles one for 60-62 and 63-66.Make sure you get the 60-62 plate pn#6062PSK
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-28-2016, 07:36 PM | #11 |
My truck is a 66. Your saying I should get the 60-62 plate? Does it fit better than the one made for a 66?
01-29-2016, 02:42 AM | #12 | |
If you have a 66 the 60-62 plates will not fit. Not to hijack this thread but do you already have the 63-66 CPP plate? If so is it not fitting? You may want to start a new thread and see what others have done . Im sure some will be able to help
01-28-2016, 12:41 PM | #13 |
Thank you to all you guys for the info. Im sitting here completely immersed in all the info. Don't know how to take it all in. First thing i need to do is get out of Chicago and back home to okla where my truck is. I probably be trying to contact you guys again in the coming weeks for some more info if you dont mind.
01-29-2016, 05:27 PM | #14 |
To put both on your truck you will need captains steering bracket for 60/62 and find a gear and pump off of like a 73 up truck... As for brakes you will need his 60/62 power brake booster/clutch bracket and a clutch master you can find the right booster and brake master in a wrecking yard
