01-28-2016, 11:12 PM | #1 |
Gas tank swishing sound when cornering
Is there any coating you can use on an in-cab gas tank that will make the swishing sound quiet down in the cab? Relocating the tank is not an option. Just would be nice to find a way to quiet it lot or even a little.
01-28-2016, 11:26 PM | #2 | |
The Older Generation
Re: Gas tank swishing sound when cornering
LockDoc
01-28-2016, 11:29 PM | #3 |
the boat guy
Stick chunks of gas tank foam down the filler neck.
Lizard skin/dynomat on the outside of tank might help.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-28-2016, 11:29 PM | #4 |
It's for my build. The cab is in body shop stage. I just remember from when I drove it how annoying that sound was. I have a new tank sitting here and was just thinking while it was not installed yet what I could do to help this stay quiet. I know it still needs to ground out so I would mask where the cab bolts to it off.
01-28-2016, 11:38 PM | #5 | |
.. I thought when you said that removing the tank was not an option that it was already installed and you didn't want to remove it from the truck.... LockDoc
01-28-2016, 11:37 PM | #6 |
Yeah dynomat might help. What is lizard skin? A paint on or a stick on?
01-28-2016, 11:40 PM | #7 |
Sorry my bad. I meant moving the gas tank to the rear frame under the bed. That would be the ultimate way, I just did not want 20 guys to throw that out.sorry. I edited my first post to relocating not removing.
01-29-2016, 01:11 AM | #8 |
I put Dynomat on mine, then put the factory cardboard over it and I can't hear the gas moving around anymore.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
01-29-2016, 01:14 AM | #9 |
Awesome. Just one the one side facing the seat or all around? If all around did the tank fit nice and snug after
01-29-2016, 07:00 AM | #10 |
x2 on the dynomat option.
Without removing the tank I put a dynomat style product on first with a high density foam over the top. I did this on one side only and now I can barely hear it. Well worth it.
John 69 c20, 396, th400, dana60, ps, ac |
01-29-2016, 07:44 AM | #11 |
70+ ( Old Skool Club )
Hey Rod, keep it full of gas and you don't get any swishing
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-30-2016, 01:42 AM | #12 |
Yes, just the one side.
01-31-2016, 10:23 PM | #13 |
Huh, thought this was the charm of these trucks.
Now I'll have to obsess about doing this.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
01-29-2016, 02:59 PM | #14 |
I have dynamat strips (don't bother covering the whole thing, it's not insulation, doesn't work that way) and then the factory tank carpet, because I have buckets.
This has two purposes - the dynamat "deadens" the tank wall and the carpet is sound insulation. Keeping the tank more full might help as well. Less room for the contents to slosh around in. My Dad had to keep the tank level below 3/4 or gas would splash out of the filler neck and onto his shoulder, and since he smoked a pipe, that was dangerous. I suppose he -could- have fixed it, but he just chose to run less gas....
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-29-2016, 08:48 PM | #15 |
I bought my insulation at Home Depot, its called Frost King. Comes in a roll and is sticky on one side. No more fuel sloshing noise.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
