01-29-2016, 05:23 PM | #1 |
69 correct air cleaner setup
Anyone have a pic I could use for a reference.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son Last edited by 70cst; 01-31-2016 at 08:33 PM. |
01-29-2016, 05:44 PM | #2 |
Re: 68 correct air cleaner setup
Which engine?
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
01-29-2016, 10:05 PM | #3 |
Forgot to mention it was a 350. I was leaving school and forgot to say that
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-29-2016, 11:31 PM | #4 |
In 68 our trucks didn't come with a 350. I have a 283 two barrell air cleaner if you like a pic.
1967custom |
01-30-2016, 01:00 AM | #5 | |
Can a mod change the title for me please?
01-30-2016, 02:23 AM | #6 | |
Visible problems in this pic: Terrible and unsafe household wiring job. Positive colored cable grounded to block. Rubber fuel line |
01-30-2016, 02:43 AM | #7 |
If I recall correctly, in 1969 the emissions present depended upon the GVWR (1/2 ton vs. 3/4 ton). If so, the air cleaner may have varied based on emissions. Here's a picture of the original on my 69 C20 made at Fremont and sold to me new in California. The only emissions present are a PCV and breather routed to the collar the air cleaner is mounted on.
01-31-2016, 08:34 PM | #8 |
Done
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-30-2016, 09:25 AM | #9 |
Thank you first owner!
Anymore out there
01-31-2016, 08:22 PM | #10 |
I have a 69 Custom/20 from Fremont as well with the same breather.
01-31-2016, 08:46 PM | #11 |
Yours looks like mine except the snorkel appears shorter with a larger, more oval "mouth". I have always thought mine was too restrictive with the opening being no bigger than the exhaust. Maybe they wised up during the year. Possibly a supplier difference or camera angle also.
01-31-2016, 10:32 PM | #12 |
Re: 69 correct air cleaner setup
Thank you for the title change, and thanks guys for the pictures. Just need to find one now
01-31-2016, 10:35 PM | #13 |
01-31-2016, 10:38 PM | #14 |
69 C10, decent old truck. Pretty original
01-31-2016, 10:44 PM | #15 |
Few pics
01-31-2016, 10:54 PM | #16 |
Could you post the vin? I can't exactly read it. If it came from Fremont then I will post a picture of the one u need.
01-31-2016, 11:08 PM | #17 |
It looks like your engine is completely stock except for the fact that the nose of your breather is missing. Just would need to find one.
02-01-2016, 12:11 AM | #18 |
Its from Janesville. Does the nose just slip on? I assumed someone had cut it off
02-01-2016, 12:14 AM | #19 |
02-01-2016, 12:52 AM | #20 |
If you have identical exhaust manifolds that don't show a portion where a hose can connect to then you most likely have the same one as ours. I also am looking really close at the image of the engine. It appears that yours was cut short by the previous owner.
02-01-2016, 01:25 AM | #21 |
Not sure but may originally may have had the Heat Stove that surround's the driver side Manifold installed
http://67-72chevytrucks.com/vboard/s...d.php?t=163280
02-01-2016, 01:31 AM | #22 |
My 350 I put back to almost all original. The intake, carb, fuel line and a few other little things have been changed
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
02-01-2016, 10:29 AM | #23 |
My 72 has the heat stove and pipe. The 69 does not. So I'm guessing someone cut it for better airflow. Thanks for all the help guys. Just gonna have to hunt for a "new" 69 air cleaner
02-01-2016, 12:06 PM | #24 |
I have a 69 GMC K10 from Fremont and it has the same air cleaner as FirstOwner69's picture. No heat riser no dashpot.
Posted via Mobile Device |
02-01-2016, 12:35 PM | #25 |
I can only assume that this one is the same also. No heat stove or tube is probably factory correct on this truck also.
