01-29-2016, 08:54 PM | #1 |
original wheel size
01-30-2016, 02:26 AM | #2 |
20' Daredevil (Ret)
Re: original wheel size
Look on the back side of the stock wheel. Most have the size stamped into them.
OK to give away your old wheels, but a paid subscription is required to sell on the board.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-30-2016, 11:37 AM | #3 |
01-30-2016, 10:04 AM | #4 |
The first picture you show is of a 6" 4 "nub" wheel that would have come on 71 and newer 4wd trucks and will clear disk brakes.
A true original to your 69 will be a 5.5" 3 "nub" wheel and will not clear disk brakes if you have or ever plan to convert your truck to disks. (they can clear with a 5/32" or 3/8" spacer) The "nubs" are the bumps on the wheel that the hub caps pop over. To measure a rim with no tire on it, measure between the lips where the bead of the tire sits. here is a link to a pic... http://www.sl113.org/forums/uploaded...im%20width.jpg If your looking at rims with tires mounted check the nubs first then confirm by looking for the stamp on the back/inside of the wheel. |
01-30-2016, 11:34 AM | #5 | |
