02-01-2016, 12:13 AM | #1 |
LSX Oil Pans
I need a f body oil pan for my.....2006 vortec 5.3 I got from a chevy truck.
Does anyone have information of what years will interchange on the shallow f body oil pans please? The truck pan hangs down about 3 inches below my crossmember. And this is not going to cut it.
1965 C10 Project |
02-01-2016, 03:58 AM | #2 |
Re: LSX Oil Pans
some guys use the holley street rod pan for the ls. some use the fbody, some use the gm h3 5.3 pan, there is the ctsv pan, and dont forget the shortest of them alll... the ls3 road race pan. likely you will need to take measurements. but yes fbody pans are on fleabay.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
02-01-2016, 11:30 AM | #3 |
Re: LSX Oil Pans
I had the same problem with my oil pan. I purchased the Moroso 7 Qt 20140 GM LS Conversion Oil pan and new oil pickup.
02-01-2016, 12:04 PM | #4 |
Re: LSX Oil Pans
I already know I need a shallow pan fellas.
My question is what models f bodys will fit the 2006 I have? Kinda stupid to go and spend $300 plus on an oil pan. When you can take one off of a car in a yard for way less.
1965 C10 Project |
02-01-2016, 01:25 PM | #5 |
Re: LSX Oil Pans
Any fbody with a ls motor is your answer to it fitting your 5.3.Get the pan and pickup tube.Put a new o-ring on pickup tube on install.Check the fitment of pickup tube.If the pickup mounting bolt seems to bind or misalign the tube in the pump slot the mounting tab hole so that it attaches freely.Some of the pull the tube off center causing them to suck air and lose oil pressure.
02-02-2016, 12:06 AM | #6 | |
Re: LSX Oil Pans
Yeah thanks for the tip on the pickup tube info too.
1965 C10 Project |
02-02-2016, 03:32 PM | #7 |
Re: LSX Oil Pans
I had same issue on my 6.0.... the pan you want is from 1998-2002 f body.. you can purchase this pan at the dealer cheaper than you can get aftermarket clones. same for the exhaust manifolds.. I would have to look it up, but I think the oil pan was around $200 and I know the trailblazer ss exhaust manifold were $80 ea. all came from my local GM dealer... Good Luck, Casey
02-03-2016, 01:55 PM | #8 | |
Re: LSX Oil Pans
Manifolds I seen online for $250 for the pair. Im gonna check out the dealer and see what they say as well. Thank s for that info.
1965 C10 Project |
02-01-2016, 01:34 PM | #9 |
Re: LSX Oil Pans
What is your yard charging for a oil pan ?
02-01-2016, 02:02 PM | #10 |
Re: LSX Oil Pans
98-02 LS1 f-body.
I don't know about yards near you, but around here LS1 f-bodies aren't just dropped in the yard for the vultures to tear apart, those drivetrains are too valuable even blown up. |
02-03-2016, 02:03 PM | #11 |
Boosted Member
Re: LSX Oil Pans
I've used the stock truck pan on a mildly dropped C10 in the past with good results. Those results were not very good after I bagged it and caught a crown in the road. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
