Simple TBI build
Hello All,
I thought i would share my new TBI build and results with the forum. I have searched a ton and finally decided to keep it simple. I use my truck as a DD and to tow my 8500lb camper in the summer. Most builds talk about max HP/torque. My bigger concern was usable torque at 2500-3500 rpm and at <half throttle. You can't tow at WOT and 5k rpm for long. For that reason I decided to keep the swirl port heads, My thought is velocity is what i am after not big flow numbers. I fully understand the limitations of these heads but for now i wanted to be back running this spring and not get into fueling and programming issues. ![]() I want to keep the motor around 2300 at 65 in OD and up to 3100 in third at a down shift. The idea is to keep it in the max torque range while working. For this build there is little value in numbers over 3500. I hope i will still get 15+ mpg around town and 10-12 towing. If i can't get there, i will build a BB and sell this motor at a later date. The cost of to build a 383 kept growing so this was alternative for now. Overview is 5.7 crate GM lunati cam full length hedmans 4l80 small block 4l80 converter (stalls higher than the BB version) 4.56 or 4.88s Anyhoo, Here it is,, I will post the pics and specs as it develops and a bin file for the computer at the end if needed. This is my OEM TBI 5.7 I sold the long block for 300 on CL. ![]() I bought a new GM crate 12568758 from summit for 1640 free shipping, no tax. (-300 for the original) new motor cost 1340. It is hard to touch that number with a local machine shop. It has hypereutectic pistons and a CR of 9.4 http://www.summitracing.com/parts/na...make/chevrolet ![]() It is a roller block but i am staying flat tappet. I am installing a Lunati cam (113$) lift .437/.454 Duration 250/256 and using the GM lifters I was going to polish the heads a little but they look decent enough. I do not want to open them up because it is the velocity at 1/2 throttle i need. The longer duration should should help. http://www.lunatipower.com/Product.aspx?id=1981 ![]() I know I could go roller but the point of this is to make my 7.4 vortec numbers (Vortec L29 454 290 hp 410 lb/ft torque) without a bunch of money and tuning. I doubt i will get there but that motor towed great and still got respectable mileage. This is the truck it is going in. ![]() If you have any input on parts,,, please advise, If you are interested in the outcome, let me know and I will continue to update. Chris Last edited by chris989; 02-01-2016 at 12:20 AM. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Simple TBI build
I'm in for the build
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Build looks good but I would have considered the GMPP Ramjet 350 cam. I dont know that it would meet your torque goals with the swirl port heads though but that Lunati cam is a strong one and should perform well. I doubt you will regret using it.
I know its a heavy burban but my buddys 91 K5 with a TBI 350/700R4, 4.11`s and I think 33" tires would get 10 mpg towing or not so you should be close.
Anthony |
Very nice/clean ride! Are those 31" tires? 4.10's will put you in the 2200 rpm range at 65 with the 4L80E's .75 OD. I would go 4.10's
The cam choice is a nice pick for the application spec wise. I would go hydraulic roller. You can get used lifters, guides, spider, and pushrods fairly cheap on Ebay. Chevrolet Performance makes a 3 piece single roller timing set that includes the camshaft retainer and bolts for cheap. I have used that ramjet cam in stock TBI applications with no additional PROM tuning and it works fine. |
#5 | |
If i decide to go roller in the future, I will probably buy some after market heads like summit or edlebrocks keeping the intake runner at 165-170 max. |
#6 | |
4.11s and 33s work back to about 3.73s I am hoping to gain tow-ability with the lower gears. |
Then 4.56's would be my choice for 33"-35" tall tires
#8 | |
![]() Join Date: Jul 2000
The RamJet cam would be a good choice for your RPM range and torque requirements. The earlier closing intake valve means lots more cylinder pressure (and torque) than the Lunati cam, and probably a wider power band. My 82 pickup has a 355 with a take-out Ramjet cam ($120) + GM roller lifters ($125), so it's not prohibitively expensive, even with the new timing set, cam retainer plate, and lifter retainers and "spiders". However, even the most torquey (torquiest?) 350 won't come come close to matching the 454's torque. Not with 104 fewer cubes, even if you rev the 350 to the moon. That said, I once had a 350 with a small Crane flat tappet cam (194/204/104) in a 69 pickup. That thing made massive torque in the 2500-3500 RPM range, even though it ran out of steam above 4000 RPM. I never towed anything heavy, but it would pull a 2000+ lb trailer over an 8,000 ft Colorado pass at WAY above the speed limit.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#10 | |
If i do the tbi crate, and go roller, i would need cam, lifters, pushods (600 ish). If i can't get the numbers from this build, I might go all out with aluminum heads and a roller set up. I just thought for the price this might be fun to try out and if it runs well it might help out other TBI truck owners. |
Curious to see where you take it. I always felt the stock TBI motor worked just fine for off-roading.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
BONE HEAD MOVE,
When i sold my old motor i left the oil filter/cooler adapter on it. I have can not locate a source for the OEM style mount (two bolts) with the cooling lines exiting the side. Are the OEM also a two piece unit? There are 100s of aftermarket stuff but I would like the original if possible. Thanks, |
I'd go hydraulic roller, it helps efficiency a little and makes oil choices far less important. Modern oils aren't great for flat tappet. I'm not suggesting an aggressive profile, though.
I'd also consider an aluminum intake manifold, they can be had pretty cheap.
1973 C20, 350/350 |
A well set up moderate roller 350 intended for truck use can certainly make more power than a smog dog 454, and likely tow about as well, but it's hard to get the off idle torque of the bigblock.
1973 C20, 350/350 |
#15 |
Hello,
I have a header question while waiting on a few parts. I would like to go 1.5 inch primary and 2.5 collector but i can not get an answer as to what might fit. Being the V series trucks, i am not sure if it is left out sometimes by accident and the tech phone guys have no real answer. Will a header from the next generation fit a square body (I know it might have the egr tube and maybe that is why it is not listed for my truck) and/or will a 2wd header fit? Thanks, http://www.summitracing.com/parts/su...00?prefilter=1 |
#16 |
In for this build. I'm getting ready to start my swap in a few weeks and it'll be nice to see how yours turns out. Great looking Suburban
#17 |
#18 |
I just hope you don't end up with a lobe going flat and metal particles circulating throughout the engine. Its not about that RamJet cam being superior performance wise, its about reliability.
If you are determined to use a flat tappet in todays world, please use generous amounts of PASTE lube such as made by Crane. ( NOT THE RED JUNK THAN RUNS OFF OVER NIGHT). Pre lube engine, use quality lifters such as Johnson or Genuine GM. Cold set the valves on the stand, use a good oil such as Valvoline VR1 in the silver bottle(10W30), Stab distributor correct, coolant in, no leaks, have everything in order to fire up ASAP and run for 15-20 minutes varying RPM from 2000-2500. Good luck! |
#19 |
TBI update,
installed the cam today, here are the specs ![]() if you don't have one of these, i highly recommend it, i have no idea how installed cams as a kid, I must of jacked up some bearings. ![]() I did grind a little on the intake, One runner was a big offender, the rest were minor. The swirl port is still the big restriction so i just touched it up some. ![]() ![]() ![]() ![]() crazy enough, the OEM heads were a lot cleaner than the intake so i just could not justify removing them, all the disassembly just for negligible gains. ![]() ![]() The other side was exact, the scribe did not even leave a mark,, go figure? The have mixed feelings about the intake,, It is really no different than stock and the only reason i bought it was because I did not want to risk a crack in the old one and by the time i surfaced and cleaned i felt it wasn't worth it. On the new intake, the holes to mount the the map/sensor stuff is off a little, I had to bend the bracket narrower and also put a small spacer under the from bolt. ![]() Also the threaded hole in the front for accessory supports is missing, It looks like it is cast in place, just not drilled and tapped. Not a biggie if you have a tap set, but it would suck to have to buy a 3/8 tap and bit just for that. ![]() I am going to mock up the headers tomorrow on the stand and see which ones have motor mount/ plug wire/ starter / oil filter issues. It is easy to want to do more to this motor but i am trying to have it run under the original chip without issue, I can burn chips and program, just thought i would try this route first. If this can not get it done, I will most likely install a set of after market heads and it will make plenty of power. |
#20 |
Chris,
I just finished installing the same GM L05 from Summit in my 87. I also used the Edelbrock 3704 and stock TBI. I am curious to see how you deal with a few of the snags that I ran into using the aftermarket manifold. Can't wait to see your updates! Have fun! Tony |
#21 | |
All of my brackets did not align with the edlebrock holes. No horrible, +/- 1/4 inch. Easy enough to fix, just thought they would have it dialed in a little better. |
#22 | |
I absolutely hate this intake, It is the biggest POS i have touched in a long time. I keep modifying and today i went to install the fuel lines and the TBI ~1inch rear of the OEM position. My vacuum barb now won't fit, throttle cable short now, and the fuel lines are almost touching the firewall instead being able to mount to the rear of the block. I already modified the brackets, power brake line, drilled and tapped for my AC etc. I want to send it back to summit but they say i can not because it is mounted. I feel i am ready to dispute the charge and toss it in the trash can. What did you do |
#23 | |
Drill and tap the front of the intake for the AC bracket. ![]() I shortened my brake booster line and used the first step in a double flare to give me a small bulb at the end of the steel line ![]() ![]() ![]() The fuel lines are still in the way of the rear vacuum port. I am thinking of plugging it and using a 3/16th tee off of one of the lines from the front. It only runs the heat/ac stuff inside. I will see if it throws a code when the if the vacuum spikes in that little line. I might end up making custom lines because my original link had a kink and i found a set at the junk yard but i am not sure how decent they are to run. |
#24 |
I am running the Summit (Flowtech) 1-1/2 long tube headers on my '85 C10, no issues except I had to dimple the #3 tube just a tad for spark plug boot clearance. I am running Dart s/s 165 heads with straight plugs.
#25 |
Header comparison
I thought i would share some pics of the two headers i bought. The hedmans win hands down. It sure would be nice if the manufactures would have real install pictures to compare.
summit (SUM-G9006) http://www.summitracing.com/parts/sum-g9006 hedman 69230 http://www.summitracing.com/parts/hed-69230 I wanted to run the smaller tubed summit but they hang so low i can not imagine not being a driveshaft issue. Take a look; Headman vs summit ![]() 69230 ![]() summit G9006 (every tube is really close to the starter) ![]() Hedmans installed ![]() ![]() ![]() ![]() ![]() ![]() The driver dropped in from the top without one issue. The passenger almost went in without removing the starter but instead if forcing it, I just dropped the starter and it also dropped in effortlessly from the top. I did have to clean up the #7 cylinder bolt holes so the threads would start, (just a few burs). Anyhooo, the hedmans collectors are higher than the frame, you cannot even see them. I did not have to dent or modify anything other than the power steering bracket which i am not even sure i need. I think i am going to run shorty spark plug and 90 degree boots. |
