Old 02-01-2016, 11:01 AM   #1
Busted67
71 Stepvan gear change
Been looking around and I'm having trouble finding the right series carrier. Research says we got a 3.73-4.10 gears and we're trying to go to a 3.08. I would love to put 3.08's on what I got but not sure if it will work. Thanks for any help.
Busted67 is offline   Reply With Quote
Old 02-01-2016, 12:34 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 71 Stepvan gear change
What size step van 1/2, 3/4 ton etc?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-01-2016, 12:47 PM   #3
Busted67
Half ton p10
Old 02-01-2016, 12:55 PM   #4
Livrat
Member #1049
Livrat's Avatar
A 3:08 ring and pinion will not fit on the carrier in your rear end, if your stepvan is a Chevy it should have a trailing arm rear suspension, you might just search around for 3:08 rear axle assembly out of a 71-72 Chevy pickup, a majority of them came with the 3:08 ratio and will bolt right into your P10
Livrat is offline   Reply With Quote
Old 02-01-2016, 01:03 PM   #5
Busted67
Are they the same width because it's bagged and pretty close as it is.
Old 02-01-2016, 01:04 PM   #6
Busted67
It's my wife's business vehicle btw.
Old 02-01-2016, 09:14 PM   #7
Livrat
Member #1049
Livrat's Avatar
If it is a 71 with the factory 5 lug axles, yes it is the same width as the pickups
Old 02-02-2016, 12:00 AM   #8
bonnieclyde100
check summit racing.com I was able to buy a3.73 that fit my 3.08 carrier and I think they sell 3.08 that will fit your carrier.
bonnieclyde100 is offline   Reply With Quote
Old 02-03-2016, 01:52 PM   #9
Busted67
Thanks I'll check that out.
Old 02-03-2016, 02:01 PM   #10
bonnieclyde100
the brand I bought was Richmond gear
Old 02-03-2016, 02:05 PM   #11
67 cst swb
67 cst swb's Avatar
FYI... you may want to double check me on this... but...
I believe the wheel bolt pattern on your van may be 5 on 4-3/4"
So swapping in a different rearend may lead to other changes,
such as swapping your orig van housing axles back in or else a wheel change.
But please double check your wheel bolt pattern as I could be wrong.
Pick-ups are 5 on 5" and I think vans are 5 on 4-3/4"
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-03-2016, 03:18 PM   #12
Busted67
It is in fact 5 4-3/4. I guess I'll just buy a carrier and gears since it's prolly easier and maybe cheaper than a trans swap. I got lucky with the van, came with a small Chevy pattern and discs up front.
Old 02-03-2016, 03:21 PM   #13
Busted67
More pics here
Old 02-03-2016, 03:22 PM   #14
Busted67
Our daughter loves it....no surprise.
Old 02-03-2016, 03:42 PM   #15
stomper
Junior Member
stomper's Avatar
Super cool P10! Did you check your bolt pattern? My '73 is 5x5.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 02-03-2016, 10:02 PM   #16
Busted67
I did not physically but that's what I read.
