'O2 S-10 engine siezed.
I bought this truck,sight unseen,for $200. (2200 Vin 5 engine)
They told me the engine was siezed,and it has a couple of minor issues,that I'm not too worried about. My question,is this,Should I get the rebuild kit($400),or another engine? I'm on a budget,so I need to save as much as possible. What are the odds it's a head,or crankshaft ? I'm not that familiar with these trucks,but I liked the price.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
Re: 'O2 S-10 engine siezed.
Another engine, find a local salvage yard. There are good runners out there.
Brad 64 C-10, 406 sbc th350, ford 9" floater |
None have any S10's,but I got a head from a '99 Cavalier,with 34k on it,for $80.
Been a while,since my post.
Got the engine freed up,and turning over. Checked the rod,and main bearings,and found no damage,or bad wear. Timing chain/tensioner is within specs . Pulled the head ,and found cyls 1 & 2 have crescent shaped holes,near the valves,causing the coolant leak. PO stated they used E-85,to save $$. It's supposed to be a "Flex-fuel"engine,but it looks like detonation damage,but the piston tops are normal. Piston clearance is right on the money,and no sign of scoring on the walls. QUESTION: Is this engine noted for head problems?
