Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 02-02-2016, 08:49 PM   #1
Boog
laying low
Boog's Avatar
Dtc c0899, c0900, c0161
2009 Yukon 4wd.
It began with the cruise not setting every time. I replaced the brake light switch and it worked fine for a few weeks. Now it gives the messages, stabilitrac and traction control issues.
These first two codes are for low voltage and high voltage at some device. The third one is for ABS/TCS circuit fault.
Is this where I give up and take it to a dealer to solve?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-10-2016, 04:37 PM   #2
Tynee
I miss this truck.
Tynee's Avatar
Re: Dtc c0899, c0900, c0161
Boog, any resolution? Everything I've seen indicates that the brake light switch is the magic bullet cure-all on these trucks. Any chance you got a bad replacement switch?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-10-2016, 06:02 PM   #3
Boog
laying low
Boog's Avatar
Before these codes showed up I had replaced the brake switch with a BWD one because the cruise started working only intermittently. It was more expensive than the AC but i thought it might be better so i went with it. Apparently it was faulty or it became so after a couple weeks.
The first two codes are old ones and once cleared have not returned. The 161 code is for the Abs/Tsc circuit fault giving "service traction control and stabilitrac "messages. Cleared the codes and installed an AC brake switch. So far so good.
Even new parts can be bad.
Boog
primer is finer
