Does 55-59 have lead seams?
On the piller post between windshield and front of door where the drip rail tappers off and ends is that a leaded seam? On my truck it's cracked straight across on both sides. I can take my finger and peal up what looks like sheet metal?
Re: Does 55-59 have lead seams?
Yes,They are normally leaded. just heat area until lead runs out,wirebrush while hot,grind area, then weld solid and finish as necessary
Hollister Road Co.
yes that's the roof to A pillar joint. You can melt it out and use All Metal in its place. Cracking and peeling are common.
#4 | ||
Thanks guys! |
