Old 02-03-2016, 10:44 PM   #1
wootownpimp
Turbo 350 to 700r4
I'm sure it has been ask on here a few thousand times, but I want to change the Turbo 350 in my 70 Suburban to a 700r4. A friend of mine says that I simple need to move the engine forward and use a different mounting location and I can move the trans mount, and it will save me from having to cut the driveshaft... Has anyone done or heard of that?
Thanks in advance for any help.
wootownpimp is offline   Reply With Quote
Old 02-03-2016, 10:50 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Turbo 350 to 700r4
I guess you could do that. Seems like the backwards way of doing things.
I know that I would make the driveshaft fit the truck not the other way around. Your shaft could probably use new joints and a balance anyways.
Fwiw I've had 3 shafts in my truck
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-03-2016, 10:52 PM   #3
dirish
dirish's Avatar
Driveshafts cut is under a hundred bucks with new u joints. Way easier.
dirish is offline   Reply With Quote
Old 02-03-2016, 10:58 PM   #4
kaycee
kaycee's Avatar
Yes tit can be done that way I did my SWB that way put new u-joints in and smooooooothh. You need to drill a coupla holes for the cossmember when you move it back easy-peasey . You will need a TV cable the life line of the 700 and the correct bracketry . Do a search it has been covered 100 times
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-04-2016, 01:39 AM   #5
Z10
Z10's Avatar
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-04-2016, 08:26 AM   #6
67 chevelle
67 chevelle's Avatar
I would not move the engine , check out a 2004r , it will go right in , if you have a tall rear gear and want a 700r4 , then moving the transmission crossmember back and cutting the driveshaft is a better choice
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-03-2016, 11:41 PM   #7
Rod Run
Rod Run's Avatar
Your friend must like to do things the more difficult way
Much easier to just redrill tranny mount holes then worry about room for your cooling system and make more weight over your front end, which would actually result in handling issues.
Moving an engine forward in a chassis, is against every principle of improved drivability for a vehicle, which is even worse in a pickup than a car
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-04-2016, 12:06 AM   #8
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
It depends on if you are talking about a 2wd or 4wd. It's its 4wd, moving the engine forward saves from having a new longer front shaft made. It also only moves the engine to the 2wd position.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 02-04-2016, 09:07 AM   #9
Bigdav160
Bigdav160's Avatar
Moving the engine involves more than drilling a few holes. The exhaust length will change, the radiator hoses, fan and pulley clearance change plus, on a 2WD, I would think there are oil pan clearance issues.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-04-2016, 09:57 AM   #10
72again4x4
72again4x4's Avatar
Wootown,
2wd or 4wd? I started this exact swap last year on my BB 4x4 and totally agree with everything said above. Never had to move the engine, just drill the new hole for trans crossmember and have the DS shortened and balanced. Much less hassle and time on the garage floor in my case.
Any questions or if you need some pics, PM me and I'll get some info your way. Hope this helps.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 02-04-2016, 12:09 PM   #11
Big Kev-O
Big Kev-O's Avatar
Not only do you need a TV cable setup but you will also need to install some sort of control for the torque convertor lock up. There are a few different options, Bowtie Overdrives and B&M both offer solutions. Like kaycee stated, a search will provide you all the info you could ever need.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
