Old 02-08-2016, 11:58 PM   #1
1972K20
1972K20's Avatar
LS Swap and Air Conditioning Question
I've got a 72K5 that doesn't have air conditioning, so none of the AC components are currently there. Eventually, I will swap in a 5.3 w/AC and was wondering what AC parts I need from the 1972 setup to run AC with the 5.3 engine? I've never tried to setup AC before, so I'm not sure what all I'd need to make it work on a truck that never had it. I don't want to start buying original ACs parts when they may not be necessary. Thanks
1972K20 is offline   Reply With Quote
Old 02-09-2016, 08:00 AM   #2
clemsonteg
Re: LS Swap and Air Conditioning Question
If your truck didn't originally have AC, then the easiest approach will be to get a kit from a manufacturer like Vintage Air or Old Air Products and purchase the kit with the LS bracket. I'm happy with my VA kit, and I did have to buy some parts for my upcoming LS swap, most of it will stay in place.
clemsonteg is offline   Reply With Quote
Old 02-09-2016, 10:18 AM   #3
1972K20
1972K20's Avatar
Do you have a pic of that? I didn't say this in my original post, but I'll be changing the dash to an original AC dash so all the original holes and vents will be there. I don't want the AC mounted under the dash or in a place that doesn't "look" original from inside the cab. Behind the dash and under the hood I'm not too worried about the "original" look.
Old 02-09-2016, 10:30 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
You don't need any original parts. None.
This ^
All you will need for the LS is a compressor mounting bracket, and compressor to fit it and you can connect to the vintage air. My truck was a non-AC truck originally, and I just cut the holes in the dash for the vents, and the VA sits under the dash. VA provides the hole templates and vents. The firewall cleans up nicely too, since the heater box is inside the cab.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-09-2016, 10:43 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LS Swap and Air Conditioning Question
You will need to buy are make the covers to cover the old heater openings though as in the pictures that Wasted Income posted. One for the fan motor and the big panel that hides all the heater openings.
If your truck didn't have AC then a kit would be the easy way.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-09-2016, 11:16 AM   #6
Wasted Income
Boosted Member
Nope, not true. The Vintage Air kit comes with all the covers for the holes in the firewall.
Turbo diesel
Old 02-29-2016, 02:02 AM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: LS Swap and Air Conditioning Question
That all depends on the kit that he buy's!
Old 02-09-2016, 11:46 AM   #8
1972K20
1972K20's Avatar
This ^
I plan on using an original AC dash and not templates because the one I have was cut up by the previous owner for a radio. Do I have to use Vintage Air's vents in the dash or can I use factory GM holes/vents?
Old 02-09-2016, 02:20 PM   #9
clemsonteg
I don't know 100% since I didn't have anything factory, but I believe you can use the factory stuff. The best thing to do would be to contact a vendor that sells the kits (I used LaidBackCreations) and tell them everything you are using/will need so they can put a quote together for you. The basic questions that will get you 90% of the way there will be things like what engine are you using, which accessory drive (truck or car), which controls (factory air or non-factory air, I used the non-factory air), etc.
Old 02-17-2016, 11:48 AM   #10
fastpace
You can use the original vents. Having a non-ac cab will be good since you won't need the block off plate for the original box, you'll just need to drill the holes for the bulk fittings to go through the firewall.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 02-18-2016, 11:04 PM   #11
Hart_Rod
Hart_Rod's Avatar
If you install a factory a/c dash, Vintage air makes a kit for that. There are separate part numbers for a factory a/c dash or non a/c dash.
Hart_Rod is offline   Reply With Quote
Old 02-19-2016, 01:38 AM   #12
1972K20
1972K20's Avatar
Great, it sounds like Vintage Air is the way to go. Thanks
Old 02-19-2016, 10:54 AM   #13
First c10
First c10's Avatar
I am about ready to order my kit for a non AC cab. where is the best place to purchase it from? or who is the cheapest?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-26-2016, 10:35 AM   #14
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
http://67-72chevytrucks.com/vboard/s...587293&page=25
Best deals around and great service
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-29-2016, 02:59 PM   #15
Wasted Income
Boosted Member
Yeah...I guess if he buys one for a chevelle, it probably wouldn't have those covers
Turbo diesel
