02-09-2016, 04:04 PM | #1 |
Brakes found on 1969 CST/10 Pickup
Hi
Curious I am looking to buy a truck 1969 CST/10 Pickup, I see a master booster and master cylinder, does this mean the front brakes could be disk brakes from the factory? Were they offered EVER or is this a power assist manual drum brake setup? |
02-09-2016, 04:17 PM | #2 |
Re: Brakes found on 1969 CST/10 Pickup
I have a 1969 C-10 CST and it had power brakes, but with drum all the way around. I am not sure if disc was offered in "69 or not.
02-09-2016, 05:09 PM | #3 |
70+ ( Old Skool Club )
Although there has been some speculation that some of the last 1970 model C10's etc. had disc brakes none has ever been verified on this site. Disc brakes were standard equipment starting in the 1971 model year. As a footnote even though disc brakes were standard you could still order a truck without power brakes so you'd have manual disc brakes. Your truck with power drum brakes is factory and not uncommon.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-09-2016, 05:19 PM | #4 | ||
"I ain't nobody, dork."
A booster and master cylinder doesn't mean disc brakes. There are power assisted drum brakes. Check behind the wheel for a drum. If there are discs there... they were swapped in as no 1969 truck came from the factory with disc brakes.
I'm in the process of swapping 1972 disc brakes over to a 1969 frame. Gary
02-09-2016, 05:29 PM | #5 |
Power drums from the factory on the 69 CST trucks (generally speaking, could be different in Canada ?) and as others have said if the truck happens to have disc on it they have been added at some point.
But, no it's not save to assume disc because of the booster / MC. Welcome to the board !
02-09-2016, 07:17 PM | #6 |
Old member
No shop manuals for 70 and back mention disc brakes for repair so the answer is No!
The only way it would have disc brakes up front is if someone has changed them out. Look at the wheel studs. The 69 should be 6 lugs! If it was a swap they would be 5 lugs inless they used a aftermarket kit.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-10-2016, 03:48 AM | #7 |
Thanks everyone, the truck is in usa and appears to have 6 lug nuts on rear so assume from has 6 as well. Can't see a disk brake upgrade being done.
Will have to have a look but will start another thread on that! Thanks! |
02-10-2016, 09:30 AM | #8 |
Agreed with most of the above - Disc brakes were ever an option in 1969 model trucks. At least I have never seen any documentation to prove such - Documentation is the key
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
