Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 02-10-2016, 09:53 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
WIW: NOS 73-87 dash bezel
Not sure exactly what years this was used and it does have a couple of imperfections in pic 2. The aluminum has a bubble in the corner and a spot of some sort up higher. If this is used, it wasn't for long.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-11-2016, 02:00 AM   #2
UKNOWME
UKNOWME's Avatar
Re: WIW: NOS 73-87 dash bezel
Well believe it or not the "if this is used" comment makes a big difference to some. If the holes look like they have had screws installed than I would say the value is approx 1/3 less at least. With the imperfections I think it's a 200-250 piece if no signs of previous use. The original box definitely helps too.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 02-11-2016, 06:56 PM   #3
too much stuff
Roadtrip!
Thanks, I see no signs of use, I just don't want someone thinking this is a showpiece. It is a very nice part. I believe it is nos and just not taken care of properly. What years was this used?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 02-11-2016, 07:19 PM   #4
UKNOWME
UKNOWME's Avatar
Looks like 84-87. Probably 88-91 suburban too
1964 Chevy c10
Old 02-11-2016, 08:05 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Good thread on dash bezel differences:
http://67-72chevytrucks.com/vboard/s...d.php?t=660034
QUOTE:
Yes, they can be grouped into 73-74, 75-77, 78-80, 81-83, 84-88.
73-74 bezels have a raised area surrounding the headlight knob hole and a fairly narrow hole for the wiper switch.
75-77 bezels have a larger hole for the headlight knob without the surrounding raised area. And a wider rectangular hole for the wiper switch.
78-80 bezels have some styling / appearance differences but I believe they are otherwise interchangeable with the 75-77 bezels as long as you use the corresponding lower steering column cover piece.
81-83 bezels have more of a squared off shape to the upper corners to match the shape of the dash pad.
84-87 (and 88 R/V series) bezels no longer have a rectangular hole for the wiper switch since it's on the column for these years. And the round hole for the headlight switch is moved up a little bit higher as compared to earlier years.
I believe the 89-91 R/V series bezels are very similar to the 84-88 bezels with the only difference being the radio opening.
Keith
Convert to disc brakes.
Old 02-12-2016, 12:19 AM   #6
too much stuff
Roadtrip!
Thanks for the info guys.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
