Installing MY6/A833 in an 85 C10.
I have recently purchased an MY6/A833 transmission to install in a 1985 C-10 that originally had a 305/TH350C combo. I have searched around and cannot find a definitive answer about the transmission hump. I know that if this truck originally had the MY6/A833 transmission, then it came from the factory with a high hump transmission tunnel. My question is... does anyone know if this transmission will fit under the low hump tunnel? The transmission looks like it doesn't have as much height as a top loader style SM465. I do not mind if the base of the Hurst shifter comes up though the floor.
Thanks, |
Re: Installing MY6/A833 in an 85 C10.
I'm guessing it will fit under a low hump floor, especially if you are willing to allow the base of the shifter to stick up a bit.
GM has a different set of requirements for clearances and durability for building a million trucks than you or I do for just our own. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I have (2) trucks with the A833. I do not believe the hump is as high as my old 4 x 4 with the "farmer 4-speed" . I actually have one of the A833 trucks ripped apart in my shop. Could get you a measurement if that helps?
Its roughly the same height and size as my saginaw in my 74 c10. I have my a833 almost ready to instal also. Keep us updated.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
![]() Join Date: Nov 2010
Pics!
