![]() Join Date: Aug 2010
Muncie SM318 Transmission
Does anyone know if the a Borg Warner overdrive R10H-1A from a Muncie SM318 transmission will fit on a Saginaw 3 speed transmission?
Re: Muncie SM319 Transmission
Any transmission experts out there?
Re: Muncie SM318 Transmission
I wouldn't consider myself an expert on these transmissions, but I have dealt with a few while helping Dad find one for his 66 C10.
Anyway, the R10 OD units are very similar and do share some interchangeable parts. But I don't think they will interchange between Muncie & Saginaw transmissions. For one thing, I believe the adapter piece that is sandwiched between the main case & OD unit / tail housing is different between the two. |
Maybe this guy can help https://pittsburgh.craigslist.org/pts/5382463741.html I do not know the guy...
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
The main cases are different, but the bolt pattern is very similar. The real problem is ya need the sag. O/D main shaft to put the R10 on the sag. Now if your tryen to use the Muncie r10 to fix a sag. r10 ya might be in business.
If anyone has any sag. O/D mainshafts I would be interested.
So the OD main shaft is different between the two? Would you suggest rebuilding the Muncie with the overdrive and ditching the Saginaw?
Tough question. if ya have a stock rear end,( 4:11 or 3:73s) you will probably miss the overdrive. And the shifter linkage from the Muncie won't fit the sag. either. My thoughts would be, rebuild the Muncie, and then start lookin for a sag. O/D or a 5 speed if you think you need a stronger tranny.
I'm not concerned about the strength of the transmission, I have a 250 six that's all stock, 155 horses. I'm just looking for a little better mileage and less strain on the engine. Rear end is stock 3.73. I want to maintain the column shifter as well, not interested in the floor shifter. Thanks for your response!
