Old 02-12-2016, 10:37 AM   #1
mikeguy
how much grease
i have a 1963 k-10 stepside that i want to clean and regrease the dana 44 closed knuckle . i think i want to use the corn head grease but i'm not sure how much to put in. any advice you guys have is greatly appreciated.
mikeguy is offline   Reply With Quote
Old 02-13-2016, 04:17 PM   #2
61K10
61K10's Avatar
Re: how much grease
I mixed some 90wt with the cornhead grease to thin it some. If your axle is stock fill the knuckles just like the center section (ring & pinion).
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-13-2016, 06:24 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: how much grease
Old 02-13-2016, 06:52 PM   #4
padresag
Re: how much grease
believe that it calls for 140 wt gear oil in the steering knuckles. there is quite a difference between grease and oil in their app[lications
ron
padresag is offline   Reply With Quote
Old 02-13-2016, 08:26 PM   #5
wilkinst
Re: how much grease
This is what I did too. Filled it until it started pouring out the fill hole.
1966 Chevrolet K20 w/ a 283
1954 Chevrolet 4400 Dumptruck w/ a 235
1950 Chevrolet 3100 w/ a 235 & T5
wilkinst is offline   Reply With Quote
Old 02-13-2016, 11:17 PM   #6
j.kirn
Re: how much grease
The correct lubricant can be bought at QUAD4BY4
j.kirn is offline   Reply With Quote
Old 02-14-2016, 12:59 AM   #7
mikeguy
Re: how much grease
thanks for all the info,once again your help puts me in the right direction. i redid a 64 c10 30 years ago and have'nt been able to do more than just routine maintence on my trucks. wife and four kids cut into my fun time. but now i can get back to doing this stuff again. so i found a pretty decent 63 k-10, most parts are at the media blaster now. so i'm working on changing all lubes and alittle chassis work so i can do the body work as stuff comes back. i've been reading on this site for awhile and it makes my head spin the stuff people do and the stuff people know here. this internet stuff is pretty cool, it makes it much easier. and know a couple of my kids are into this stuff too.
Old 02-14-2016, 02:22 PM   #8
61K10
61K10's Avatar
Re: how much grease
mikeguy post up some pics--I have heard many different types of oil/lube for the knuckles. I'm pretty sure (can look again) in my manual it calls for 90w gear lube. I used reg u-joints on my axles so my lube will only lube the knuckle's and the knuckle bearings.
1961 chevy K10
Old 02-14-2016, 02:52 PM   #9
padresag
Re: how much grease
140 wt is what we use to put in them at IHC, and 90 wt for winter months. I have seen 140 in the Dana literature which I have somewhere.
In section 0 of the manual it does call for 1/2 pint of 90wt
ron
