Old 02-13-2016, 11:29 AM   #1
moosefd
66 suburban 5.3 swap
I'm building a 66 suburban trying to put the 5.3 out of an 04 Chevy truck into it. I have the motor mounts figured out and I'm gathering up other parts for the swap. My question is and I know it has probably been asked a hundred times will the truck exhaust manifolds fit without doing anything to the frame or do I need to try and find Camaro manifolds or headers? I will only be lowering truck about 2-3 inches so ground clearance isn't an issue.
moosefd is offline   Reply With Quote
Old 02-13-2016, 12:07 PM   #2
72MARIO
72MARIO's Avatar
Re: 66 suburban 5.3 swap
From what i have read you can not use the factory truck manifolds without cutting/heating bending the frame. 1998-200? 2010 up camaro or trail blazer manifolds fit most swaps. Hooker makes swap manifolds that fit
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-13-2016, 08:39 PM   #3
Clyde65
Clyde65's Avatar
Tbss manifolds work best for our trucks if you want sto stay factory lsx.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-13-2016, 11:16 PM   #4
moosefd
what are tbss manifolds ?
Old 02-13-2016, 11:56 PM   #5
ls1nova71
ls1nova71's Avatar
tbss=Trailblazer SS
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-14-2016, 01:11 PM   #6
Advanced Design
Advanced Design's Avatar
A friend built a 66 Suburban with the 5.3 and he used the Trailblazer SS manifolds.
Advanced Design is offline   Reply With Quote
Old 02-14-2016, 05:36 PM   #7
68basket
i have personally used tbss manifolds and the hooker manifolds. Both worked out very well.
68basket is offline   Reply With Quote
Old 02-14-2016, 08:34 PM   #8
moosefd
Has anyone used the shorty hooker headers?
Old 02-22-2016, 12:25 AM   #9
moosefd
Started the install of the 5.3 into the 66 looks like the ac compressor is going to be a tight fit in the lower position . Will it clear or is there another route to take looking for some ideas thanks
Old 02-22-2016, 11:29 PM   #10
Advanced Design
If you decide the go high with the ac compressor Holley has a good solution. This bracket is for a Sanden compressor.
https://www.holley.com/products/acce...y/parts/20-134
Old 02-22-2016, 11:36 PM   #11
moosefd
Thumbs up Re: 66 suburban 5.3 swap
Thanks for all the replies I found a set of 2010 Camaro exhaust manifolds with the cats still on them locally. Tried them on and only had a small amount of clearance problem on motor mount nothing big. Decided to try and keep the ac compressor on the bottom for now and had to make a small notch on the frame. Tomorrow night maybe I can make the trans mount and get it all bolted in.
Old 02-24-2016, 11:48 PM   #12
moosefd
All right got motor and tranny in what are you guys using for a driveshaft. The orginal with the carry bearing or the driveshaft from the doner vehicle, I need all the help I can get here from someone who has done this before ,thanks.
Old 02-22-2016, 12:30 PM   #13
Clyde65
Clyde65's Avatar
best to use the high mount.
I used Docs Blocks and trimmed the frame rail a tad. I don't know if Docs Blocks are used any longer.
actually here they are.
http://www.acsource.com/hoseblockhor...oringtype.aspx
Clyde65
Rebuild of Clyde
support our troops!
Old 02-22-2016, 12:57 PM   #14
Hart_Rod
Hart_Rod's Avatar
2010+ Camaro manifolds are da bomb....
Hart_Rod is offline   Reply With Quote
