Old 02-16-2016, 12:41 PM   #1
ptc
ptc's Avatar
NEW 588" Merlin Alum Block BBC w/ ProCharger
588 Cu. In. Supercharged BBC ENGINE Ready to Run
Merlin Alum Block 4.625” Bore
Internally Balanced, SCAT Crankshaft 4.375” Stroke, SCAT Rods, Aries Pistons, Total seal Rings, ARP Studs throughout
Moroso Alum oil pump, Pan
Merlin Alum Intake Manifold, 4150 base flange
AFR 350 Magnum Heads Alum. 116cc Chamber
Deck height @ 0.00”, Head Gasket .048, Comp Ratio 8.22
Manley titanium Intake Valves, Exhaust Valves, Titanium Retainers
Comp Cam HYD Roller Cam
Comp Cam HYD Roller Lifters
Comp Cam Dual Roller Timing Chain assembly
F2 Pro Charger Self Contained, Pulley Setup to produce 18LB Boost
Blow off Valve, High Velocity Carb Hat
Holley 850cfm Blow Thru, Carb Shop Prepared
Includes: Electric Water Pump 50 GPM, MSD Ignition, Carbon Fiber Valve Covers, All Stainless Steel Oil lines, Extra SC Pulleys
This is a complete ready to run engine from carb to pan. $36K invested in total build. ASKING $27,500.00 Will prepare for shipping at cost.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
