Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-16-2016, 07:11 PM   #1
Jrgunn5150
What can I run?
I have a 79 C10 Stepside. It has a more or less stock 400 in it. I bought it pretty much as is, so here's what I know,
400, 882 head's, Performer intake, Quickfuel 1957 carb, header's, TH350, 3.08 gear's.
More or less, a stock truck I'm guessing. It runs ok, no rocketship.
If I were to go to Vortec head's, a medium flat tapped cam, a RPM intake that would put my compression at around 11:1, or less, depending on the dish in the pistons, but regardless, I'm going to say that I can easily pull 375 flywheel HP from this motor.
Would that, plus 3.73's or 4.10's, and some D/R's be enough to get me down around 13 flat?
The truck is a weekend truck, I might drive it to work a couple times a week in nice weather. I just want respectable performance out if it, because right now, even though it sounds cool, anything on the road would leave it in the dust.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 02-16-2016, 08:35 PM   #2
cableguy0
Re: What can I run?
Vortec heads are definitely not the answer. They don't flow enough air for a performance 400ci engine. They would be fine for a stump puller but wont allow you to run much past 4500rpm before they start choking the engine. To go 13 flat your going to have to upgrade heads past the vortecs. You will need a cam in the mid 230-low240@.050 duration range and .550 lift or so. The gears will make a huge difference but unless the engine can turn the rpm to use the gears down the track it wont do much good. First off whats your budget because that will dicate the overall build.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-16-2016, 08:40 PM   #3
Jrgunn5150
Re: What can I run?
I'm starting to see that in other research.
I have no fixed budget or timetable. If I need to wait to get AFR's or whatever, then I'll wait. It's fun to drive, a nice hot rod, sounds cool, looks cool, it's just I've had fast car's before, and I know this truck is a poseur lol .
I also know, that right now, i have a blank canvas, but what I think is a decent foundation. I just don't want to buy part's twice or go down any dead ends. I just don't see alot of street/strip trucks, everyone wants to slam them or jump them lol.
J.R.
Old 02-16-2016, 09:23 PM   #4
cableguy0
Re: What can I run?
First step upgrade to 3.73 and a posi in the rear. You will be shocked at how much the truck wakes up especially from stoplight to stoplight. Also sticking all those go fast parts on top of an unknown bottom end is a recipe for disaster. You will want to have the bottom end rebuilt and start with a decent hypereutectic or forged piston. You will also want everything balanced if you plan to turn much past 5000rpm. The 400sbc is externally balanced from the factory and wasn't intended to spin 6k+rpm.
Old 02-16-2016, 09:34 PM   #5
Jrgunn5150
Re: What can I run?
For this year, i think that I will settle on a set of 3.73's, a True Trac, and I'll work on getting it dialed in it's current form, as it does run well, and ride nice.
If I can consistently run decent times with it, I'll go from there. I know 400's aren't forgiving as far as being bored over, it's my understanding .030 is it, so if it comes to that, I'll punt the thing and build something more appropriate.
Thanks for the help!
J.R.
Old 02-17-2016, 12:56 AM   #6
Captainfab
60-66 Nut
Re: What can I run?
Here's some reading for you.
http://www.67-72chevytrucks.com/vboa...0%2F406+builds
Captainfab is online now   Reply With Quote
Old 02-17-2016, 01:13 AM   #7
Jrgunn5150
Re: What can I run?
Originally Posted by Captainfab View Post
Thanks! There's some good info in there, but I'm really interested in ET's, in a truck.
Can a leaf sprung truck, with a mild/medium 400, run a decent number? i guess I'll find out one way or another lol.
J.R.
Old 02-17-2016, 01:25 PM   #8
68c10owner
68c10owner's Avatar
Re: What can I run?
http://www.superchevy.com/how-to/148...-block-torque/
Anthony
68c10owner is offline   Reply With Quote
