L99 LS3 Truck Water pump question
Ok so i have been doing a LOT of reading and such about the different water pumps available.
I have an 03 suburban engine that will be going in my 86 C-10. one thing that i had sort of planned on was using the suburbans mechanical? fan which is attached to the water pump pulley. if i am able to stuff the engine in the bay in the right spot i will not need to modify the fan shroud for this to work properly, or at the very least not need to modify it much. however the trucks as we all know have a left side upper radiator hose and i personally think it is kind of dumb to install a 4 foot upper radiator hose (ok. this may be a bit of an exaggeration) simply because the dumb inlet is slightly right of center on the engine. i had planned on using a custom radiator with both inlets positioned on the right side to accommodate this situation, but i am not thrilled at the prospect of paying big bucks for a custom radiator. so the new thought to me is is that maybe i could get away with using the camaro or ls3 vette water pump. The L99 or LS3 water pumps both feature left hand inlet ports allowing for a slightly shorter upper radiator hose. So to the question i have been getting at: NEITHER the LS3 or L99 water pumps appear to have provisions for the mechanical fan attachment, and rightfully so. BUT i do see that the pump and housings are of coarse separate parts and i am wondering if i can install the actual PUMP assembly from a truck into a L99 or LS3 housing to allow for the fan to be bolted to the pulley? does this make sense? I do realize the difference in pulley spacing and the L99 being on the truck spacing vs. the LS3 being car spacing would require the water pump spacers that are so commonly available. of coarse the odd bit is that i believe that on my 03 Suburban the fan is held in place with 4 bolts while the newer ones are held in place with a single centrally located nut? has anybody done this or know specifically what will or will not work? conjecture is great but without parts in hand some questions simply cannot be answered. thanks in advance. Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Re: L99 LS3 Truck Water pump question
What you're basically wanting to do is press on a truck pulley on a car water pump? It can be done, I've seen it, but it's not as easy as that. You have yo take the pump apart so you can back up the impeller when pressing it or you will destroy the pump. Some of the older pumps the back plate unbolted but the newer ones have a pressed in piece and I'm not sure you can get that out and back in with out doing harm. Other people will tell you to just run electric fans, but personally I like mechanical fans and would just deal with the 4 foot hose!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I think I understand what you are looking to do but I dont think it will work.
If you use a L99 Water pump the outlet comes straight out toward the radiator near the pump pulley. If you then install a truck pulley and fan you wont be able to install the upper radiator hose as it will hit the fan blade. I think thats the reason the truck pumps outlet is on top, to get over the fan and shroud. |
#4 | |
Looks like i am back to the custom aluminum radiator option again. I would love to do electric fans but just not ready to tackle that yet. Izzy
#5 | |
EDIT: GM only lists one water pump, same with RockAuto. This leads me to believe that the L99 and LS3 pump are, in fact, the same pump, with truck spacing. ACDelco 251734 / GM 19207665 I can definitely confirm the mechanical fan would most likely hit the outlet: ![]() Last edited by foamypirate; 02-19-2016 at 12:31 PM. |
Camaro's that came with an auto trans have DOD and therefore an L99. The water pump on the l99 has the truck spacing to fit the sensor on the cam that's behind the pump.
The Camaro's with a manual trans have LS3, and therefore the short spacing that would require the spacers to work with truck accessories. Just clarifying for those searching for answers in the future. |
