Old 02-18-2016, 11:05 PM   #1
Tony S.
Lightbulb Drive shaft
Anybody know of any Portland Oregon based companies that will cut driveshafts down without charging you an arm and a leg?
I've checked a few out and their saying anywhere from $350 to $500!!! That's ridiculous! More if it's HD and even more if you want new U-joints.
The price goes up and up and up. They charge for prep, then charge for first cut, then additional charge for second cut, more charge for weld, more charge for powder coat, more charge for new U-joints, then additional cost for paint... By the time your done your well over $600!
Can I get a few names of reputable places please.
Thanks all!
Tony S. is offline   Reply With Quote
Old 02-18-2016, 11:19 PM   #2
Wrenchbender Ret
Re: Drive shaft
That's completely out of line. There is a place here in KC that shortens one for $60. He built me one completely out of aluminum with new U-joints for $300.
Wrenchbender Ret is offline   Reply With Quote
Old 02-18-2016, 11:19 PM   #3
60chevyjim
60chevyjim's Avatar
Re: Drive shaft
dam that's a ripoff .
I just shortened a driveshaft for a V8 chevy S10 for a guy I know and I charged him $35
I used to get them done in phila pa. when I lived there by a driveline shop for around $50
60chevyjim is offline   Reply With Quote
Old 02-20-2016, 12:33 AM   #4
Tony S.
Re: Drive shaft
You don't happen to live close to Oregon do you? hahaha!
Old 02-20-2016, 02:01 AM   #5
Captainfab
60-66 Nut
Re: Drive shaft
Having a driveshaft shortened should be no where near that expensive. You should be able to get a completely new driveshaft built for $300-350. It's been years since I have had one shortened, so I don't know what the current cost is around here.
Check out LostMy65's build thread. He bought a new driveshaft for his truck and the cost wasn't that bad.
Old 02-20-2016, 02:44 AM   #6
kerber63
kerber63's Avatar
Re: Drive shaft
I had Anderson Brothers in Eugene work on a couple drivelines for me. Shortening one cost about $50, building a new one (I supplied the ends) cost about $125. They're a big truck repair place, maybe you can find something like it around Portland. They weren't as stuck up as some auto driveline shops around the area.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 02-23-2016, 02:20 PM   #7
Tony S.
Re: Drive shaft
Thanks a lot bud. I appreciate your help!
Old 02-25-2016, 12:09 AM   #8
Tony S.
Re: Drive shaft
Definitely gonna check them out! Thanks!!
Old 02-20-2016, 10:55 PM   #9
Monte's62
Re: Drive shaft
Never been to Oregon Tony, but I hear it's Reeeal Nice. If nothing else I could drop off a bed full of small block 350's for TJ.
Best of luck finding someone to do the job for you, as mentioned by everyone, this shouldn't cost a lot of hard earned money.
Monte's62 is offline   Reply With Quote
Old 02-21-2016, 02:11 AM   #10
'63GENIII
'63GENIII's Avatar
Re: Drive shaft
In my area, most everything is ridiculously expensive. The DS guy that I keep using in San Jose will build a completely new HD driveshaft for under 300 from a sketch on a piece of paper. He will use a combo of brand new and good used parts on hand. One day turn around in most cases.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-21-2016, 02:27 AM   #11
64shortbox
64shortbox's Avatar
Re: Drive shaft
There's not much to shorting a drive shaft. I watched an episode on a Hot Rod TV. They just chuck them up in a lathe, turn down the weld at the yolk, cut the drive shaft to length, slip the yolk back into the shaft weld it up and then check for balance. NOT a lot of labor time.
64shortbox is offline   Reply With Quote
Old 02-19-2016, 11:53 PM   #12
Monte's62
Re: Drive shaft
Well I knew that brother-in-law would finally be good for something. He has awesome welding skills and I got an awesome deal.. Hate to rub it in guys.....FREE!!
Old 02-20-2016, 12:31 AM   #13
Tony S.
Re: Drive shaft
Well thanks all! Yeah I figured I was getting raped on it. I just figured I would ask.
Hey, send your bro-in-law on over here to Clackamas Oregon.
Old 02-23-2016, 02:37 PM   #14
siggyfreud
siggyfreud's Avatar
Re: Drive shaft
I think I had these guys do mine years back. Couldn't have been that expensive as I was in college. But it's possible it was another place and my memory has failed a bit in the last 5-6 years.
http://www.driveshafts.com/
siggyfreud is offline   Reply With Quote
Old 02-23-2016, 11:59 PM   #15
Tony S.
Re: Drive shaft
These are the ones who gave me the terrible quote!
Old 02-24-2016, 12:38 PM   #16
siggyfreud
siggyfreud's Avatar
Re: Drive shaft
I must be remembering the place wrong then, or they changed pricing since. I think I paid about $110 to have them shorten my shaft and add new Ujoints back when I did it.
Old 02-23-2016, 06:25 PM   #17
jayoldschool
Moderator
Re: Drive shaft
Got a grinder and a MIG? Do it yourself...
jayoldschool is offline   Reply With Quote
Old 02-23-2016, 11:58 PM   #18
Tony S.
Re: Drive shaft
Grinder, yes. Mig, no.
Old 02-24-2016, 12:27 AM   #19
suburban99
suburban99's Avatar
Re: Drive shaft
Grinder, welder and dial indicator and it's not too hard. There is a good video on youtube...I did my own.
suburban99 is offline   Reply With Quote
Old 02-24-2016, 12:24 AM   #20
60chevyjim
60chevyjim's Avatar
Re: Drive shaft
do you know anyone that can weld it if you cut it ?
I have done more than 20 at home with no lathe .
and I never had 1 balanced .
3 of the trucks I have now I cut the drive shafts .
I shortened two and
made one longer for my blue S10 yard push truck .
I shortened the one in the red n black truck with a 454
I shortened the drive shaft in my wifes 51 chevy
that is on a complete running 1985 V6 S10 chassis
that I built for her 3 years ago.
they are the first 3 trucks in the picture.
the green 97 S10 I swapped the whole running chassis wiring and the bed.
that took A 100 thousand miles off the truck ,
it had 250,000 miles now it has 150,000 miles and cruse control .
if you need any info on cutting the drive shaft yourself and having someone else weld it email me .
Old 02-24-2016, 10:39 AM   #21
scoot_mcgrute
Re: Drive shaft
Six States off of Columbia does all my driveline work and they are priced well too!
Give em a call, 503-249-1010
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-29-2016, 03:11 PM   #22
Tony S.
Re: Drive shaft
Wow! Thanks a bunch bro'! I will definitely be calling them.
custom drive shafts, drive line, drive shafts
