02-19-2016, 07:05 PM | #1 |
Removing switches
Got my 62 cab stripped and ready for epoxy, well all but the switches,lol. How do you get the CIG lighter out, ignition switch has a ring but apparently a combination to get it off. Headlight switch? Wiper switch I'm good. Choke? Last thing holding me up spraying tomorrow.
02-19-2016, 07:25 PM | #2 |
Re: Removing switches
Headlight switch has a button on the side (on the body behind the dash) Press the button and pull on the knob.
To remove the ignition, you will need the key and a paper clip. I believe you turn the key to the accessory position and insert the paper clip into the small hole next to the key. Good Luck |
02-19-2016, 10:35 PM | #3 |
One foot in front of the other
u get them out ok?
02-19-2016, 10:51 PM | #4 |
But Found Her 25yrs Later!
http://www.earlyclassic.com/tech.asp...064-66%20Chevy
The headlight rod and knob are removed by first pulling the rod to the on position and by reaching under the dash and depressing the spring- loaded button found on top of the headlight switch itself. Depressing the button allows the rod to slide out of the switch, and the bezel can now be removed.
02-19-2016, 11:05 PM | #5 |
Not out yet. Haven't been back out to it. They will be out in the morning. The one that really stumps me is the CIG lighter. I found a set screw on the wiper switch, so that's covered, choke has a nut on it, thanks for the help on the headlight switch and ignition switch. Ready to get this thing epoxied and primed.
02-19-2016, 11:13 PM | #6 |
cig lighter is two pieces and unscrews from back of cluster.
02-20-2016, 11:21 AM | #7 |
Got em all out...Thanks guys,I was about to start ripping and tearing,lol. Now to shop vac the blasting media out, blow off and wipe down.
