02-21-2016, 02:45 PM | #1 |
Help! these pulleys are making me crazy
My power steering pulley does not line up what do I have wrong. I thought I had all the right stuff but I guess I don't.
02-21-2016, 03:02 PM | #2 |
Re: Help! these pulleys are making me crazy
I had a similar situation. I just put a double sheave on the alternator nose and used the forward groove.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-22-2016 at 08:24 PM. |
02-21-2016, 03:19 PM | #3 |
Wrong lower pulley
02-21-2016, 03:33 PM | #4 |
What does the lower pulley suppose to look like
02-21-2016, 03:56 PM | #5 |
72 350 pulleys.
The lid is stuck on my jar of anti seize |
02-21-2016, 06:18 PM | #6 |
I'd change the pulleys
02-23-2016, 01:05 AM | #7 |
02-21-2016, 07:42 PM | #8 |
Ok thanks i guess i on the hunt for another pulley
02-21-2016, 07:43 PM | #9 |
When I was putting my 72 GMC 1500 4x4 together I had a similar stiuation I couldn't find the proper pully for the power steering pump so I ended up using a 4 groove crank pulley and just left the 3rd groove from the inside empty. It works fine and I've never had a belt jump off
Ugly 61 |
02-21-2016, 08:02 PM | #10 |
Always on the hunt...
If you are able to read the pulley p/n on your pump, let me know know the # and I may be able to tell you the p/n for the matching outer crank drive pulley. Mel
02-21-2016, 10:03 PM | #11 |
The part number is 3925537DC
02-22-2016, 09:16 AM | #12 |
I have an extra set of pulleys I had powder coated black, when I get home from work this evening, I'll take a few pictures and post them.
If they might work, you can have them for the cost of postage. Ben |
02-22-2016, 10:53 PM | #13 |
02-22-2016, 11:00 PM | #14 |
I have to dig through my stash first thing in the morning, I remembered I moved a rubber maid tote out to my storage shed, And I'll snap a few pics showing the diameter and depth using a tape measure, perhaps that will give you a better Idea of whether these will work for you.
Ben |
02-23-2016, 01:04 AM | #15 |
02-23-2016, 03:25 PM | #16 |
Per our old archived short water pump pulley records, we have used your listed p/s pump pulley p/n 3925537 with outer crank two groove add on drive pulley p/n 3923898 on small block applications and also with outer crank single groove add on drive pulley p/n 3925525 on the big block applications. If you end up sourcing a different pulley setup, another very common small block short w/p pulley combo for p/s is pump pulley p/n 3993325 used with the outer crank single groove add on drive pulley p/n 3751232. Hope that helps some, Mel.
02-23-2016, 04:26 PM | #17 | |
02-24-2016, 01:27 AM | #18 |
interesting pulley. that puley is identicle to a pully used on an aftermarket ac unit instaled on my 68 k20.
I will burn off a picture of a correct pulley that may work for your alternator. its wider than a single groove style but not as wide as a 2 groove pulley. took for ever to find it but there it was, in a corvette catologe......and priced accordingly....ouch |
02-24-2016, 03:30 AM | #19 |
Old member
Couple of my old setup.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-23-2016, 12:21 AM | #20 |
I don't think you have the correct lower crank pulley setup on there now, can you take a better picture, a little closer with flash on the power steering pulley too?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-23-2016, 12:39 AM | #21 |
Looks like in the first pic that both the alt and power steering do not line up? Is that correct?
02-23-2016, 01:29 AM | #22 |
I have a set of proper pulley's in my garage and pictures on my home computer i can post later but they look like the set in post 5, the one set on the engine looks like its from a long water pump setup.
I am questioning you power steering pump, mounts and pulley at this point.
02-23-2016, 05:38 AM | #23 |
Here they are.
02-23-2016, 08:53 AM | #24 |
Its kind of a bad photo I took but the alt lines up just the power steering is to far fwd. What does the correct power steering brackets look like
02-23-2016, 08:58 AM | #25 |
Mine aren't even close to that, much deeper on the bottom pulley, don't know about the water pump pulley, figures I forgot to grab them on my way out the door this morning.......
Ben I'll get those this afternoon for sure. |
