If you need defroster duct hose.....
Went to Napa and they had this part number--looks good and got 6' for I think 15 bucks....
![]() Join Date: Jul 2015
Re: If you need defroster duct hose.....
2 3/4 inch tube diameter?
I want to say it was 2.5" and fit very snug. Fairly easy to get on the LH duct while the RH duct took a bit of work and grease but per other posts it seems that working the hoses onto the ducts can be laborious. I'll take some pics of the hose this week.
Made by Dorman Products, and your right 2.5 inch diameter. I think mine requires 2.75 as I remember.
If I have to do mine again I will only use the heavy fibreglass stuff for the bottom visible pipe. I'm going to use bilge vent pipe, which is similar, but much easier to work with.
Also the parts are getting old and brittle nowadays, so clamping a big fibreglass and spring reinforced pipe onto your defrost vent and installing it without breaking a tab off isn't easy! Not to mention there's barely enough room for the pipes to be routed as it is.... it's pretty packed back there in an AC truck.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: Jun 2012
Packed in there like a can of sardines
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Dunno, this stuff slipped on no problem. I used some wire twisted around the duct just above the little keeper notch and it worked well. Easy enough and looks stock as it has the wire loop running through the tube like the original. Wasn't exactly happy going on the RH duct but if I had to do that over again I would modify that somehow with a round adapter or something--the oval shape is a pain and not really needed.
thanks for the tip. I'd like to see some pics
