![]() Join Date: Jan 2016
Turn signal connector
I have a 1967 C10. I am rewiring the engine bay to fix a lot of shaky wiring the PO did. One of the things that is missing is one of the rubber turn signal connectors. driver side, that goes through the front support. Both the connector from the turn signal light and the one from the wiring harness are gone. Believe it or not the PO used wire nuts to connect the wires! Anyone know where I could get these?
Dale |
Re: Turn signal connector
American auto wire or if you can post a pic and I'll look on my old harness and see if I have it
I think I have the harness side connectors and possibly the light side also I'll let you know later tonight
That looks like the plug to the voltage regulator, and the wires have been jumped for an internally regulated model of alternator.
I need on of those connectors too! (like ga-stepside needs)
My problem with my harness is it has a small amount of voltage on the ground. I disconnected the grounds and touched them to the frame and voila the lights come on. I'm missing the rubber plug that connects to the drivers side turn indicator. Any tips where I can find will help! Thanks |
#9 | |
![]() Join Date: Sep 2007
im going to be bypassing my og turn signals from the 67 if you like i can sell you the plugs.
1967custom |
I have an extra front light harness I'm not using, it is missing one side of the turn signal plugs, but I have replacements for that.all the other plugs are there, and in working order. I believe,
This is from a '69 C 10, should work with your truck, let me know if you want it. Yours for the cost of postage..... Ben ![]() Last edited by snipescastle2; 02-25-2016 at 11:29 PM. Reason: adding pictures |
#13 | |
Ok, I'll post some pictures of the connectors later today, them phone camera pics leave a lot to be desired....mostly clarity.....
Ben |
