02-23-2016, 11:23 PM | #1 |
ac compressor wiring question
hey all! have a question regarding my ac compressor. Ive installed a 2015 lt1 from a silverado and am using the stock gm ac compressor. Ive wired the clutch to the binary switch. My question is do i need to wire the compressor solenoid to the same input? Obviously the silverado wiring diagram shows the on/off signal from the ac control module, which I obviously didn't use. Im running the gen iv vintage air kit. The clutch operates correctly like it should yet it doesn't build any pressure in the system
02-24-2016, 01:20 AM | #2 | |
Old member
Re: ac compressor wiring question
I'm not sure if I following your statement. If the clutch is engaging and working then it has to be putting pressure into the system. Well at least the older systems does anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-24-2016, 07:47 PM | #3 |
Your clutch seems to work? I think you have other problems. Make sure you have oil in your compressor. Is the system charged? Can you give us the pressure readings on the low and high sides? If it's charged, you may have an expansion valve missing or stuck open. Give us some more info, well be glad to help.
02-25-2016, 09:24 AM | #4 |
Yeah the clutch engages like it should. Looking at the wiring diagram above i think i need to put positive voltage to the solenoid to allow the compressor to compress. We've pulled the pressure back off of the system to fix a small leak in an oring. I will charge it back up next week with power to the solenoid and see if thats the issue. I wanted to use a vintage air compressor but couldn't find one to fit where i needed it and there are no brackets etc. available for these engines yet.
02-25-2016, 11:26 AM | #5 | |
Msgt USAF Ret
This was done when the AC controller was selected for AC via the B+ wire in the diagram. The diagram leaves out the power source for the clutch relay and the solenoid valve. Another question, is the solenoid built into the compressor or is it a separate inline valve in your system? Researching Gen Air's website shows better diagrams but you aren't using their controller or compressor. I wouldn't recommend running the clutch until you figure out how to open the valve first.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-25-2016, 01:46 PM | #6 |
Msgt USAF Ret
Here's another wiring diagram that shows it a little better.
I think the low and high pressure switches act as the flow controls.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 02-25-2016 at 01:59 PM. |
02-25-2016, 01:56 PM | #7 |
Mechanically speaking, have you pulled a good vacuum each time you've opened the system? You aren't "jumping" the clutch to engage are you?
02-26-2016, 10:41 AM | #8 |
so looking at your diagrams, the solenoid should be constant 12 volts with the binary switch controlling the compressor clutch? As is the clutch engages when plugged into the binary switch. My initial thought was to have the binary switch engage both the solenoid and clutch. Its tied into the vintage air system so obviously thats the only high/low pressure switch in the system.
02-26-2016, 12:54 PM | #9 |
Msgt USAF Ret
Rather than speculate on what you should do, or not do, based on the mix of the two systems, I would suggest that you take the truck to an AC specialist near you who could look at what you have, and recommend the correct solution.
Tags |
mine and grandpas c10 |
