LS swap oil pan
I just purchased a 2005 6L and tremec 6 speed for my 66 C10 conversion , the pan is wrong so I will need to swap that , which pan works best in the 66 ? does anyone sell everything to change it ? or does the 5.3 truck pan work best ? thanks
Re: LS swap oil pan
GMpartsdepot Canada from my order this week.
1 Dipstick. Engine Oil Dipstick. 12584737 $21.00 1 Engine Oil Dipstick Tube. Oil tube. Tube. 12584738 $24.64 1 Engine Oil Pan. Oil pan. 12631828 $204.76 1 Engine Oil Pump Pickup Tube. OIL PICK-UP. Suction pipe. 12621299 $84.78 That's what works the best from searching. its a CTS-V oil pan F body also can work depending on engine setback . Hummer pan can help with ground clearance but not fully above the crossmember.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
