Old 02-24-2016, 07:58 PM   #1
jmillsUT28
What is this plug and where does it go?
Hey guys, getting ready to for paint and saw this electrical plug under the steering wheel. Right where the steering shaft goes threw the firewall. I do not see where it mounts to or what it even is. Can anyone point me in the right direction?
[IMG][/IMG]
jmillsUT28 is offline   Reply With Quote
Old 02-24-2016, 08:00 PM   #2
71swb4x4
71swb4x4's Avatar
Re: What is this plug and where does it go?
That is your neutral safety switch. It mounts to the column about where you found it. You should find the square hole and the two screw holes in that area.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-24-2016, 08:00 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What is this plug and where does it go?
That looks like the neutral safety switch. It mounts to the steering column.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-24-2016, 08:09 PM   #4
jmillsUT28
Awesome. Thanks guys will get under there and mount it. Not sure how I did not see it.
Old 02-24-2016, 09:13 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Is that also the back-up light switch? If so can your Neutral Safety Switch function properly and your back up lights not work?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-24-2016, 09:37 PM   #6
Andy4639
Old member
Andy4639's Avatar
Yes. it's two circuits in one that works off the gear tit in the column. The piece in his hand has screws that you adjust on the column to set it by. It can get out of position and either one may are may not work.
Old 02-24-2016, 10:03 PM   #7
Already Gone
Thanks for the info Andy.
Old 02-25-2016, 12:58 AM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's REAL interesting. I haven't had back-up lights since I was a a young buck. Figured to get it right with the rebuild. Will be taking a good look at that switch, and the screw adjustment I can't visualize at this point.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-25-2016, 01:03 AM   #9
Andy4639
Old member
Andy4639's Avatar
Once you install it on the column it will have some slop in it. Take and get the neutral first and then see if the lights work when in reverse.
The silver tips with the screw holes are slotted for adjusting it.
Old 03-03-2016, 06:21 PM   #10
jmillsUT28
I have search 4 times and can not find a hole or opening in the lower part of the steering column. This is the steering wheel that is on it. Is this the original one?
[IMG][/IMG]
Old 03-03-2016, 07:52 PM   #11
swamp rat
swamp rat's Avatar
Should be just 2 screw holes, I believe that is not the original steering wheel but don't know the year of your truck.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-03-2016, 08:29 PM   #12
Andy4639
Old member
Andy4639's Avatar
Question Re: What is this plug and where does it go?
Has it been changed over to a straight drive?
Old 03-03-2016, 08:50 PM   #13
Husker
Husker's Avatar
What year did they start using NSS?
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-03-2016, 09:43 PM   #14
Andy4639
Old member
Andy4639's Avatar
That is a late 70's 80's model steering wheel. The opening should be on top of shaft towards the floor.
http://www.67-72chevytrucks.com/vboa...d.php?t=279795
Old 03-04-2016, 09:31 AM   #15
jmillsUT28
Hey Andy, this is a 1972 Blazer. Has been messed with but the SPID says it was a Auto. In that picture what year is the steering column on the left? It does not have a hole at the bottom of the shaft for the switch. Looks like it is higher closer to the steering wheel. As mine has no screw holes or anything close to the firewall.
Should there be a part number stamped in on this column?
Old 03-04-2016, 09:41 AM   #16
jmillsUT28
I looked at that link. Looks like this might be a column out of a van. Some what they said the van columns did not have a spot for the NSS. Looks like I need to buy this switch that mounts to the trans.
Thanks for that link it saved a lot of searching!
http://www.jegs.com/i/Lokar/625/BL-1...2/-1#reviewTab
