Old 09-23-2003, 05:50 AM   #1
RON WOODGEARD
Resident Young Old Dude !
Question Are any of you running electric water pumps on the street?
I was up to Summit a few weeks ago and seen a couple of electric water pumps intended for street use, I forget the names right now, but they look good and one imparticular pushed a very reasonable amount of water. It cost in the $250.00 range. It would really clean up the front of the engine. nothing but a belt for the alternator and power steering pump.
Any experience with them??
Ron
RON WOODGEARD is offline   Reply With Quote
Old 09-23-2003, 09:04 AM   #2
bigjimzlll
bigjimzlll's Avatar
No experience..just a thought..The OEM pumps work so well, and the after market ones work even better. If you are going to put 10k miles a year on your truck, I wouldn't go electric. If it fails...and you dont catch it in time..ouch.. The main advantage to an electric pumps is to be able to cool it down between passes. It will save a small amount of HP..but the alternator will work more..using a little more HP too. When I looked into going electric, I would of had to relocate the alternator to a bottom mount
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-23-2003, 11:32 AM   #3
miket
miket's Avatar
I have a CSI on my Chevelle...it pumps quite a bit of water...I think it advertises 40-50gpm. I drive my Chevelle on the street...it does not stay cool...I have done a little research, called griffin (who makes my radiator), called CSI, called summit, Called flexalite...they all (except CSI) said it's the water pump...this was 6 months ago....they said noone makes an electric that can pump enough water. Just my 2 cents.
they look cool.....and they do sterilize the engine compartment a bit.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-23-2003, 12:10 PM   #4
RON WOODGEARD
CSI, is the one I was looking at, It pumps 37 G.P.M. but if it's not enough, I guess this answered my question.
I was going to hit Summit for a few things today or tomorrow. Thanks, you saved me $259.00 + Tax, and a few headaches.
$259.95
Vendor: CSI Performance Products
Product Line: CSI Billet Aluminum Electric Water Pumps
Material: Aluminum
Finish: Anodized Clear
Height: 6 in.
Maximum cooling for maximum performance
Chevrolet: 283, 350, and 400, anodized clear, electric, street/strip, water pump
Generating an incredible 37 gallons per minute of coolant circulation, this CSI electric pump gives you the flow you need without costing you horsepower. CNC-machined from T-6 aluminum, the lightweight (5 1/2 lbs.) pump has a direct drive 12V motor spinning a redesigned impeller on a stainless steel shaft. A CSI pump draws just 5.8 amps, and because it doesn't run off of your crank, it won't eat up race-winning horsepower. Other features include a corrosion resistant finish, superior RFI-suppression, and removable center section for cam adjustment or replacement. Accepts a 3/4 in. NPT water inlet (not included).
Ron
Old 09-23-2003, 12:18 PM   #5
miket
miket's Avatar
Ron,
I see alot of cars (street cars) in magazines with electric pumps....these things are really designed for drag racing.
Here is a pic of mine....
Old 09-23-2003, 12:33 PM   #6
RON WOODGEARD
Mike,
Exceptionally nice, and mean looking, and tire wearing, and neck snapping,,
Do you have a Tilt front end pull off, or what?
Ron
Old 09-23-2003, 12:35 PM   #7
miket
miket's Avatar
Fiberglass hood, bumpers, and trunk lid.
Just a play toy...to tease the imports with.
Old 09-23-2003, 12:37 PM   #8
RON WOODGEARD
Your alternator sees more torque then their whole motor !!!!
Old 09-23-2003, 03:40 PM   #9
lukecp
Formerly yellow72custom
lukecp's Avatar
I know a guy running a electric water pump and electric fan on a daily driven '80 Chevy C10. I questioned that at first, but the guy recently graduated from Wyo Tech, and really knows his stuff. He said that it made the truck run alot better, and reccomended that i get one for my truck. I dunno about the electric water pump, but i will look into getting a electric fan setup one of these days.
One thing to keep in mind, the electric water pump and fan draw alot of power. Proably a good idea to upgrade to a bigger alternator at the same time.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-23-2003, 04:52 PM   #10
miket
miket's Avatar
I run a 63 amp on the Chevelle...it barely runs everything....fans, water pump and Barry Grant fuel Pump...I would say 100amp....thats what I had in my 71....pic below with fan setup...
I would really like to run an electric on the street...just alot of money to find it may not work.
Old 09-23-2003, 06:25 PM   #11
Jesse 67 c-10
Jesse 67 c-10's Avatar
Does anyone know flow #s for a stock or aftermarket crank driven water pump? 37 gpm is a lot! think 7 5-gallon pails of water in under a min. The coolant has to have time to cool off in the rad otherwise it goes back hot. Something to think about,
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 09-23-2003, 11:12 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think I read that a stock belt driven unit is something like 50 GPM. But I may well be way off.
In Car Craft, they did an article on this a coupl;e years ago. The OEM manufacturers say that when cars go to a 32 volt system ( ) that THEN they can make a streetable electric water pump.
