09-23-2003, 01:25 PM | #1 |
Wanted, 1970 4X4 drive shaft
I need a main drive shaft for a 1970 4X4 long bed auto truck. Located in central Missouri.
09-24-2003, 11:10 PM | #2 |
Well, Whoop-dee-do!
Do you need one for a 1/2 or 3/4 ton? What transfer case & trans do you have?
09-25-2003, 12:35 PM | #3 |
It's a 1/2 ton with a turbo 350, but i'm not sure which transfer case I have. I think it's a 203. How can I tell for sure?
09-25-2003, 12:48 PM | #4 |
Well, Whoop-dee-do!
203's have hi & low loc, and hi & low "unlocked". 205's have just 2hi, 4hi & 4low.
09-25-2003, 02:25 PM | #5 |
Sounds like I have the 205 case then. I have manual lockouts on the hubs and only one shift lever. The pattern is dash- 4lo-N-2hi-4hi- seat. I usually only work on old cars and race cars. I don't know that much about the old trucks. This truck is for sale by the way.
10-10-2003, 11:30 AM | #6 |
Does anyone have a drive shaft or know what kind I need to get?
10-12-2003, 01:09 PM | #7 |
Born Psycho
Beau,
the original driveshaft for your truck is a huge 4inch tube. you're better of having a new one built out of smaller diameter tubing, in my opinion. you stated earlier that you mess around with race cars so i'm sure your driveline shop would give you a good deal on a custom built unit. if you're set on a oem shaft, try bill at vintage chevy truck in fremont calif, 510-651-5874. by the way, if your truck has the 350/205 combo in it, any 70-72 longbed 1/2 ton 4x4 shaft will fit.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
10-13-2003, 03:44 PM | #8 |
Thanks for the info. It'll probably be much easier to just have one made.
