Old 02-29-2016, 01:41 PM   #1
68c10owner
68c10owner's Avatar
power steering pulley removal
Just took the kids to school and noticed a nice puddle in the driveway when I got back. Seems to be power steering fluid. Cant find any obvious leaks from the hoses but does seen wet behind the pulley. I see evidence of fluid being sprayed around the front of the engine. Figure Im due for a pump anyway and they are fairly cheap. What the best way to get the pulley off without a air compressor? This is in my 85 GMC C1500 305.
Anthony
68c10owner is offline   Reply With Quote
Old 02-29-2016, 02:45 PM   #2
raceman6135
Dino burner
raceman6135's Avatar
Re: power steering pulley removal
The pulley is likely just pressed on: no retaining nut or bolt.
Use the proper puller that grabs the groove around the outside of the pulley's hub 'nose' and remove it with common hand tools/wrenches.
There are common jaw-type clamps, like this one:
And also ones that use a collar around the clamps, like this:
Most auto parts stores should sell or rent them.
raceman6135 is offline   Reply With Quote
Old 02-29-2016, 02:51 PM   #3
68c10owner
68c10owner's Avatar
After taking a second look and looking at just the pulley mount you are correct that it is a press on. I was more concerned with the source of the leak and just figured it had a nut like my old chevelle had. That makes it a bit easier. Thanks.
Anthony
Old 02-29-2016, 05:37 PM   #4
Dead Parrot
When I needed to do that, I was able to borrow the proper tool from Autozone, which is where I bought the pump from.
Dead Parrot is offline   Reply With Quote
Old 02-29-2016, 06:44 PM   #5
MountainGoat1966
Use the puller in the second pic, it safely grabs the groove on the shaft.
And the kit also presses the pulley back on.
DO NOT use a jaw type puller, it will bend/warp/distort the pulley and render it useless.
Parts stores sell/rent the set, I bought mine at HF for less money and it works just fine.
Just note, it takes a few minutes to figure out how to use it and which length bolt to use.
Once you have done the job with that tool, it's easy after that and only takes a minute to perform the task.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 02-29-2016, 07:26 PM   #6
68c10owner
68c10owner's Avatar
Thanks guys. How did you reinstall the pulley? I dont have a press to press it back on. Hammering it back on with a block of wood would work but does it mess up the pump? Use to install harmonic balancers that way on old 283/327 cranks that werent drilled for a balancer bolt but never liked the idea of it.
Anthony
Old 02-29-2016, 07:39 PM   #7
barry1982
The second puller in the picture is also used to press the pulley back on. NEVER try hammer on with a block of wood etc. Will screw up your new pump for sure! (Ask me how I know this)
barry1982 is offline   Reply With Quote
Old 02-29-2016, 07:41 PM   #8
68c10owner
68c10owner's Avatar
I didnt think it was a good idea which is why I asked. I didnt like doing it on my balancers back then either but I was a dumb kid and didnt know any better.
Anthony
