Wheel selection info
I am currently trying to decide on the wheel backspacing i would need for my 2-4 dropped 90 silverado. It's know that i want 20 inch boss 338 wheels and i know what tire size that i want. I just need to know what width wheel i would need and the proper backspacing i need for said width. I'm wanting 275/45r20 tires which if my calculations are correct would put the tire diameter at around 29.7 inches. I've read that you'd need a wheel width of 10 inches for that tire but I've also seen where people have mounted them on 8.5 inch wide wheels. Just not sure if that would roll the bead inward or not and I'm wanting the tire to be more or less flush with the wheel. I may decide to lower it another 2 inches all the way around in the future. Has anybody else ran this size tire on their 88-98 chevy and if so, what was the backspacing?
Rollin' Old Skool
Re: Wheel selection info
The backspacing specs are on their website here:
http://www.bossmotorsports.com/wheel...d=1920&cat=466 However, unless something has changed, you can't choose your backspacing on these. You have to run what's available for the particular wheel size you want.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
Tags |
wheel back spacing |
