Old 03-04-2016, 04:40 PM   #1
Crazy Rusty
Crazy Rusty's Avatar
Question Drop Crossmember for swb only?
Was ready to pull the trigger on one but then I read the details and every one I find says 'designed for short wheel base trucks'. Anyone put these in a longbed 2-piece?
crossmember
Thanks!
Crazy Rusty is offline   Reply With Quote
Old 03-04-2016, 05:17 PM   #2
Crazy Rusty
Re: Drop Crossmember for swb only?
Bought it anyway... now I just need to get my air ride in...
_6372CNK Rear C-Notch Kit $119.00 1 $119.00
_6372LDL Drop Center Crossmember 1963-72, kit $199.00 1 $199.00
_6372SRK 1963-72 Rear Shock Relocator Kit $59.00 1 $59.00
_CPSBB Carrier Bearing Bracket 1963-72, each $22.00 1 $22.00
_CPPCB Carrier Bearing - billet and polyurethane, each $109.00 1 $109.00
_376 Trailing Arm Bushing, rubber, each $32.00 2 $64.00
_6072RUBS 1960-72 Rear U-Bolts, stock length, pair $49.00 1 $49.00
_6572DATB 1965-72 Adj. Track Bar - 24 long, ea $59.00 1 $59.00
Old 03-04-2016, 05:33 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I bought the one from POL, it has adjust-ability at the trailing arm mounts.
But I "think" the long bed unit may have a drive-shaft bearing mount?
Old 03-04-2016, 10:31 PM   #4
60chevyjim
60chevyjim's Avatar
I like this one
60chevyjim is offline   Reply With Quote
Old 03-04-2016, 06:41 PM   #5
Crazy Rusty
Mine looks like this. The new one has he bolt holes for the carrier bearing... Can't figure it why it would matter if it's a long bed and maybe it really doesn't since multiple sites don't say that.
Old 03-04-2016, 08:23 PM   #6
Slow Build
Slow Build's Avatar
Porterbuilt has a trailing arm crossmember for a two piece driveshaft.
http://pbfab.com/63-72-trailing-arms...ece-driveshaft
It doesn't have any details though.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
