03-06-2016, 03:09 PM | #1 |
Replacement Steering Bearing?
My truck has an after market steering wheel. The steering shaft is loose and clunky. When I took it apart, found that the bearing only had half the bearings in place and the whole affair was loose.
Is there a replacement steering bearing that is an aftermarket improvement? This mechanism seams way over complicated.
Capt. Paul Mansell 1974 Chevy Stepside |
03-06-2016, 04:20 PM | #2 |
Re: Replacement Steering Bearing?
Is it tilt or none tilt.. do you have pic's of your set up where it loose?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-06-2016, 04:23 PM | #3 |
It's tilt steering and I did not take a photo sorry
03-06-2016, 04:46 PM | #4 |
I assume top bearing?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
03-06-2016, 07:07 PM | #5 |
03-06-2016, 08:24 PM | #6 |
I'm considering changing the whole column out for an Ididit. Any thoughts on that?
03-06-2016, 08:52 PM | #7 |
If you take your wheel off have you tighten the three screws & lock tighten them.
if they get used a lot and have a few yr of miles on the them the get loose GM never put lock tighten on them. They are meant to be checked after so many miles. have you check them LINK:http://bowtieguy.proboards.com/threa...r-repair-renew
