Old 03-06-2016, 05:07 PM   #1
Jeramy
Jeramy's Avatar
picture request/park brake
I am in need of some pictures of the intermediate park brake cable holders on the passenger side for a 73-83 long bed c10. I ordered the two front right guides from LMC but am having no luck figuring out how or where they hook into the frame/cross member and which direction should be up.
part numbers 9 and 10 for reference. and thank you in advance for any help i can get.
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 03-06-2016, 09:23 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: picture request/park brake
9 goes in the side frame left, on inside. on the right goes to side frame, on the inside. 10 cross member or the cradle should be long more to the right side. you should be able to see it. piggy tail side goes to the cable.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-12-2016, 08:51 AM   #3
Pontiac1976
Look's like a nose mouth right side frame rail near back side of tire.
